shearcroft
Re. 944 heating I’ve just fixed my heater not not going cold inside traced to water valve on rear engine by Bulk head it closes by vacuum with engine running when switched to cold on dial if you listen carefully you can just hear the vacuum control solenoid click The seal inside the water valve had failed so water still passed through it , to test remove valve hold in closed position & water should not pass. When dial is gradually turned to warm the blender flaps inside heater unit then control amount of heat from then. PeterPSH said:Cheers Martyn, I'll keep an eye open when pennies allow... I'm hoping that my son will make a start on removing the dash in the not too distant future, that would be a good time to take a closer look at the smaller details.
BTW, was it you who kindly sent me some thermister sensors a year or so ago? For the life of me I can't find the damn things, would you have the part code so I can track some more down please, I seem to recall mention of them being available from RS? Fixing the heating is the top priority once the dash is removed.
Pete
