Sadly today under the 30 degree heat - whilst trying to raise the roof, the mechanism failed leaving the roof half mast, alas due to my foolishness of pushing and pulling I have snapped what I believe is the B pillar. Does anyone have any tips or suggestions on where to look for replacement parts ? I have looked at Design 911 and Douglas Valley breakers but parts seem thin on the ground as doe the absence of any detailed drawings?
944 cabrio roof diagrams and help needed
- Thread starter Odiente
martin.girdlestone
Try eurospares.com - great for parts / diagrams
Chrishazle
The roof of the 944 cab and the 968 cab are identical, when a fellow 968 cab owner broke her roof some time ago the only source of spares was Ebay USA, IIRC the seller is 944reanimation. I have the cab top pdf, PM me your email address, it's about 3.5Mb.
Thanks Chris, This is really helpful and I am grateful for your response. My email is odiente@icloud.com. I will have a look at 944 Reanimation immediately. All the best. DanielThe roof of the 944 cab and the 968 cab are identical, when a fellow 968 cab owner broke her roof some time ago the only source of spares was Ebay USA, IIRC the seller is 944reanimation. I have the cab top pdf, PM me your email address, it's about 3.5Mb.
Chrishazle
968CabTop.pdf
drive.google.com
The link may email me and ask if it's OK for you to open it.
First up I'd check the mechanism in the boot, remove the NS side panel, make sure the operating cable is properly in place.
Second, on the side panels in the back seat area there should be a round plactic cover each side, this is the access to the "bolt" which is the emergency raising and lowering mechanism for the roof, probably got instructions in the roof manual.
I have also emailed the pdf to you - you might want to edit your email address out of your post!
Thanks again Chris, I am familiar with the manual operation from last year when I had to get the roof up despite the immobiliser being dead… I may have over tightened something also I did count turns - but I will check the cable, I think the motor went yesterday and then the roof snapped purely due to my hubris in trying to push and pull it - hindsight and the RAC would have been a godsend but I think the breakage was inevitable at some point. Hoping I can get the part I need, and get it fixed for under a few grand - sadly I have just spent a small fortune on my 3.2. Carrera - so a fix in 2025 is probably unlikely! Thanks again for your excellent assistance.
