seventhheaven
Trying to fix a 944 Cab electric roof for a friend. If you know the circuit you will know that there is a control module that controls when you can open and close the roof - I think the primary restriction is speed (or lack there of) as the module has a connection to the speedo - but also a seperate hall sensor. If I bypass the module with +12v and an earth it all works properly including the limit switches - but not when supplied through the module.
The module has 12v to it and a good earth, but I can find no information about what the module is looking for to give it the right conditions to release the supply to the roof.
I am making an assumption that it is not a defective module as friend had already changed that with no success.
Any insight or info would be appreciated.
