I'd like to hand this query over to the Forum Collective...
Steering and suspension Can anyone out there help me locate the source of a rather disturbing noise emanating from the NSF suspension / steering of my 930? It happens when the car is being driven between 10 "" 40 mph at near to full right hand lock. The noise sounds like there is something dislocating itself then popping back in when the steering is centralised. There is no noise when turning left and I have had the torsion arm bushes replaced and there is nothing obviously worn such as wheel bearings (recently replaced). I have had various people pulling, pushing and prodding around and been unable to find the cause. I have not removed the suspension leg for inspection as it works fine over speed bumps/potholes although I have been told that a broken spring can sometimes make this sort of noise. The car is fitted with RUF wheels with low profile tyres that are slightly wider than standard. Thanks in advance for your help and cooperation in sorting this problem. Also where should I look for water getting in behind the rear passenger seat? Thanks in advance for your thoughts and comments. Bryan ![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
