VYY930
I've just "invested" in a 1985, 930 and she's great. Heavier on the steering and clutch than I had anticipated but I can get used to it.
Anyway, I've only had her a day or two now and I filled the tank up with a "No name" brand of unleaded fuel. I also slung in a small amount of lead additive which the last owner advised. Anyway, I started her up at the garage and drove around for 40 minutes or so getting used to driving it (nothing heavy at all!). When I got home I parked up on the drive. A few hours later I tried to start her but she was having none of it. It was cranking over but not firing. I called out a recovery guy (lucky I took that out with my insurance!) and he turned the engine over with is foot slowly pressing down on the accelerator until she fired up (took a fair bit of cranking over mind you!). I and apparently the previous owner have never had to do that. She starts on the turn of the key each time normally.
After getting the engine running again each subsequent attempt at starting her working fine but.....after leaving it off for 15 minutes or so, she refused to start. We finally got her going again but I dont hold out much hope for my next attempt tomorrow.
I will look in the history file and see when the distributor cap and rotor arm were last changed as my feeling is this might need doing. The car was never used much by the previous owner and has 79000 on the clock (only about 9000 of which has been done since the start of 2002).
Could it be anything to do with the "cheap, unbranded fuel" or something more sinister?
Also, the gearbox was completely rebuilt in 2002 but occasionally I get bit of a crunch in 3rd. Is the syncro likely to be worn already after a mere 9000 miles use. The last time I went out in it by the time I had driven for a while it seemed to be MUCH better. Could this be down to the fact that the last owner of the car only covered a small amount of miles in his 2.5 year ownership and merely needs a bit of "running in!"?
Any help greately appreciated.
Chris
Chris
