Have pulled out the carpet and watched the rear latch mechanism operate as I press the electric release button. The centre section motors/rotates through about 80 degrees till it stops (?limit switch?) and then returns to base. Both operating rods are connected and moving - but the hatch is not released. I assume it was designed so that very small upward pre-load from rubber surround was intended to lift it a fraction when latches pull away ?
I read somewhere that Porsche had so many complaints about non-functioning that they issued some sort of disclaimer as to its actual function as described in owners handbook?
Could it just be that someone has over adjusted the pins and the latches are not able to come free ?
When I used the key, after numerous attempts it unlocked once. But having shut it again it defied numerous further attempts.
I'm hoping someone will say it is a simple adjustment issue.
