Ok... the infamous 924 Turbo Cab went in for MOT today - failed on hand brake performance, one of the brake hose securing grommets broken on the strut, one winker bulb decided to play up (which if it had just been that, then percussive maintenance would probably have got the certificate, and the awkward one, emissions...
So the question... where on earth do you start with a total unknown to get the emissions right? Given that the car has never had a clean bill of health in 6 years, and I don't really want to/can't afford to replace everything, where do I start?
For those to which the figures mean something, C.O. should be under 4.5%, it is 11.759% HC is ok at 436ppm (max permissable 1200ppm).
It runs quite evenly on tick-over, but doesn't seem to pull that well. That said, as the MOT station is literally across the road, it hasn't been out of first gear.
My best guess is that as its revs up and dies back as one would expect, that the metering head is working ok. On that basis, I am wondering if I should suspect the fuel pressure regulator, or warm up regulator - which-ever you like to call it. One other thought though is on my 944 Turbo, the engine temperature sensor wreaked havoc with the emissions - am I right in thinking there is no such control on the 924 Turbo?
It is a 1981 car, so assume S2 or 177, depending how you wish to refer to it!
TIA, Tref.
TIA, Tref.
