GBee
Afternoon all, frustratingly my sons 924 2.0ltr all of a sudden refuses to start and so I thought I would post here in the hope somebody else has had a similar issue and could provide some insights.
The car was running fine with no Gremlins save for the headlights switching off then back on again on 2 occassions the previous day to when the problem occured.
Now the car will not turn over at all (battery ok), all ignition lights come on and contactors/relays can be heard to operate but nothing else. This to my knowledge hasn't occured before and I'm not sure what to check next, heater fan, windscreen wipers (inc rear wiper), side lights, brake and indicators all operate as does main beam flash but headlights will not come on (possibly because the engine is not running?).
I've replaced the ignition switch unit, the old one was split and wouldn't operate properly at the starting position but didn't hinder starting the car when it was running previously.
I haven't tested yet at the starter motor solenoid position as the heat shield requires removal but again this was fine until this problem occured, could this be an issue?
Finally does anyone know of a good mobile technician in the East Midlands area who could carry out diagnostics as the car can't be moved?
Regards and a Merry Christmas to all, though not so merry here at the moment
Graham
Graham
