912 oil filtration
- Thread starter BAN430G
BAN430G
Labour
Oil filtration
Remove fan belt, crank pulley, rear tin, tin behind crank pulley, exhaust and oil pump cover
Clean and check oil pump
Die grind out oil pump to fit elbow for new oil pump cover
Mount filter head
Fit oil pump gears to cover plate and fit to engine with new gasket
Plumb oil lines between cover plate and filter head
Fit oil filter and top up oil
Re-fit all other parts
Run engine to check for leaks
Parts
Oil pump cover plate
Oil pump cover plate gasket
Filter head
HP1 oil filter
4x NPT to BSP adaptor fitting
2x 90 bends
2x 45 fitting
2x Meter of oil line
2x Exhaust gasket
2x Litre of Valvoline VR1
Sundries
