Having problems starting a 1986 911ss
It will start when cold and will keep starting until it gets up to temperature
when its run for approx 10 mins and then switched off by the ignition key it will not start again...until it has cooled down.
have check the DME relay...seems to be working fine and have disconected the No 3 temperature sensor and this cause the same problem ....when the car is cold
could it be this....is there anyway of checking it???
oh by the way when it is running, it runs fine and does not miss a beat
initially thought it was the fuel pump...hence checking the DME relay
would be most grateful for any responses
cheers!!
cheers!!
