718 / PCM 4.0
tony.lister
I’m having issues with my PCM 4.0.
My car is a late 2024 718 Cayman.
The screen keeps going blank. It’s under warranty & the OPC has agreed to replace it.
The problem is they say it needs to be coded to my car (fair enough), but they keep telling me they’re unable to get a delivery date from Germany, & are unable to provide a reason why!
I’m getting the feeling they’re reluctant to push to get this resolved with any vigour.
Anyone else had a problem with the PCM unit 4.0, or had one replaced under warranty? OR had any similar issues with obtaining a replacement from Germany.
Thanks, Tony.
If parts are on back order, the time it takes for them to arrive is anyone’s guess unfortunately. Of the car is still drivable then get the car back and ask them to give you a call when the new PCM is back in stock.
Dan
Tony,
My 718 Cayman GTS 4.0 PCM map also went blank after restarting at a roadworks traffic control. I recalled this glitch last happened on one of my previous Caymans. A fix to restore the screen involved pressing a certain control button together with the right hand knob below the screen. After trying various combinations of buttons together with pressing the right hand knob, the screen suddenly came back live. The fault has not recurred since.
Unfortunately I cannot recall for sure which sequence of buttons I pressed to restore the screen. I mentioned this fault to my local OPC in the hope they would confirm the correct sequence of buttons for this fix. They had never heard of this.
This glitch has not happened again in over 1200 miles of travelling, including using the sat nav map. I can only assume it was either a one-off fault, or my random button pressing miraculously worked.
Brian.
