7 & 9 Fuch.
porkersc
Will the 9's fit under the arches of my 88 Carrera? Also what tyre size would you suggest? Thanks Dan.
Tons of room with 245/45x16. Compared to the 8 inch wheel that came as std on the 89 3.2s, most of the extra width is on the inside. With over 2 degrees negative camber on my car I can run 14mm of spacers to push the wheels out a little more, but without the spacers, there is plenty of clearance on all sides - see picture below with the spacers in place. With careful wheel selection, you can get up to a 275 tyre on a 9.5 inch rim under the rear guards. A 10 inch rim might need the springplate bolts shaved and the oil lines relocated.
