4WD light!!!
- Thread starter skendrick
Dave Wilkinson
This is one of those problems that can have a multitude of logical causes - and quite a few illogical ones too. The most obvious things to check are battery voltage and hydraulic fluid level since the PDAS system is particularly critical on both.
One of the most common illogical causes of this type of problem is high voltage ignition leakage causing the ABS/PDAS systems to go berserk. Bad coils and/or distributor caps and rotors were the cause on my car which took more than a year to diagnose!!
Try the easy/cheap stuff first before you spend out loads of potentially unnecessary money.
Dave
marlin
When they gave up, so did I and traded in [
Sorry not very helpful, maybe diagnostics have moved on from the nineties
I had a similar problem a few years back when the 4WD light came on as I drove over a particularly bumpy surface in road works. Adrian Streather had posted much info regarding this on the Rennlist technical site, one comment being that if the PDAS/ABS warning light comes on intermittantly, then this is usually due to a dynamic component failure (ie one that needs movement) such as a speed sensor or acceleration sensor.
From his various postings of info I decided to check the speed sensors on the rear wheels and found that the plastic case holding one had popped open and it was therefore not reading correctly. A simple job of clipping it shut adain solved the problem.
As Dave said, it could be due to a number of problems, but I would recommend looking at Adrian's info on the Rennlist technical forum, you might be lucky too and find it's somthing simple.
Regards,
Mike
skendrick
I checked the Rennlist website and then checked my brake fluid level as a first port of call.
My fluid level was near the minimum level, so I topped it up and now the light doesn't come on any more.
I think it works now, but I am also having fun in the snow sliding the back around (at all of 10mph).
Living in Reading we have had lots of snow in our close, so far the porsche is the only one that's managed to get out to get supplies.
Most of the neighbours have new'ish cars but couldn't get up the slight incline to the main road (not that that's bean salted either!).
They didn't think the Porsche would do it but she drove straight out and back down again without any problem.
We all went out on Wednesday and cleared the road but more snow came down that night, so we gave up (Picture attached).
asjasj
Was interesting to be able to brake harder than is sensible on snow and feel the difference with and without ABS anyway!
Ade
The only saving grace was the fact that the car started to slide right, so the oncoming car realised something was wrong befoe I slid out in front of him and slowed down in time to go round me. Pulse rate has only just dropped to near normal levels now that the car is back safe in its parking space.[&o]
MarkK
Well-known member
PS Martin that sounded close no harm done though TG!
ORIGINAL: epoch911
This light comes on in mine regularly...but bizarrely, it only goes off as I pass Bristol Airport. In exactly the same spot! Never anywhere else. Ever. Regardless of temperatures (engine or outside). Figure that one out! [8|]
Ant
You have entered the Twilight Zone
http://www.youtube.com/watch?v=NzlG28B-R8Y
appletonn
ORIGINAL: MarkK
ABS control unit fault???!!Been cleared apparently its not doing it now..
I didn't think the ABS fault codes could be read (or cleared) using the 'hammer' tool, especially on the early 964s?
Porker993
I was told that the hydraulic brake booster pump was on its way out, due to faulty seals, and would need replacing at a cost in those days (2002) of approx £1,000. I was told this was a common fault with C4s.
This coincided with me selling the car.
Dave Wilkinson
The ABS/PDAS system on the C4 has always been accessible by a "hammer" - it's the solely ABS system fitted to the C2 which cannot be accessed.
Mark,
The extended settle time for the hydraulic pressure is often attributable to the system needing a bleed. A recent primary bleed on my C4 reduced the pump time from 90 seconds down to little more than 15. It's a lot cheaper than a new pump!!!
Dave
