400 bhp.
blade7
Well-known member
400 bhp from a 2.5 turbo? Interesting thread on Pistonheads re 968 CS v late 944 turbo. A post from someone called Eldavo :) stated that their 400 bhp 2.5 8v was their best B road car. And although it was before my time here, I read about the dyno day when I think a couple of well modified cars made 400 bhp. And another with just a bigger turbo and a MAF kit made around 380 bhp. I think they were probably all running over 20lbs boost on the day, and I wondered with supporting mods, what would be a safe maximum long term boost to run.
I think it needs a little more than 20PSI plus a bigger turbo, different intake set up, dual port wastegate electronic boost control, exhaust etc etc. It can be done fairly reliably, but I think you have to be very careful with air flow monitoring, boost control, knock monitoring, wideband monitoring and ideally feedback of all of those, so probably aftermarket ECU. It is good to monitor IATs, EGTs and oil temps as well. You will want some decent internals in there too for reliability. It will also depend on the use case, occasional heavy foot on the road compared to hard lapping on track will have an effect on reliability.
With a cam change and good airflow it might be possible to make it to 400BHP at 20PSI.
Tony
