4.5 coolant pipe issue
- Thread starter davew993
Gordon Attar
First post on here. I have a 2004 Cayenne S, and I recently lost about 2 litres of coolant a week after the last service. I cannot see any obvious leaks anywhere. I have only just bought the car, which has 85,000 miles. Cannot see anything mentioned in the service history about coolant pipe replacement.
Is this an obvious first place to start?
I did notice that the header tank cap seemed not to be on tight, so this might be the problem, I will check again in a couple of days to see if any loss.
However reading this thread has me thinking this might be the problem. Is replacing the pipe a DIY job? I am pretty handy with the spanners, but have never worked on a Porsche before.
If this is the problem, what is the cost of replacement pipes?
Thanks in advance
Bollotti
T911UK
Well-known member
About a days job to change if you are handy with the spanners, we list a kit here
http://www.type911shop.co.uk/shop/article_4817/Cayenne-S-_-Turbo-%3E%3E06-Water-Hose-Update-Kit.html?sessid=Z2kieRbvjf53yOrRs1v0EUtmpedIQIOpXVTQtKU3tJI6fh032VH4TrxBA4AjED6a&shop_param=cid%3D578%26aid%3D4817%26
Gordon Attar
The pipes can be a diy job if you are reasonably handy with spanners and fairly confident about what you are doing. There is an excellent complete write up on how to change the pipes , again on Rennlist and can also be found if you do a google search. It's by an American company that supplies a kit in the US.
