3 angle valve job
- Thread starter Guest
MikeH
He's a one man band, with nearly 30 years experience. His overheads are small, so his prices tend to be low.
Edited to add pics of work - VW golf heads
[IMaGe]http://img.photobucket.com/albums/v512/mikehorsb/Golf/DSCN0462.jpg[/IMaGe]
I'm based in Chiswick. Well the heads have been sent off. The bad news is that apparently one of the barrels may need to be skimmed and therefore they need to do all of them.
Now waiting for some kind of price indication and time frame. In the mean time I have to hire a car (bugger).
No I won't be doing it at dealer prices. Bad news is the guy has gone on holiday so it's delayed the job being finished. So at this stage it is looking verymuch like the car will not be finished before Sept[
Will keep you posted.
Cheers[8D]
MikeH
Will try and get some pics. It won't be till next week though as the heads etc are still at the machine shop.
I'm speaking with them regarding doing some porting. It's all good.
Nothing new this week other than the injectors have been sent off for cleaning and testing. Hopefully they will not require replacing. I'll let you know.
MikeH
He reckons there's not much benefit to be had from porting 911 heads, as they're pretty well finished from the factory, but there might be the few horses to be had, and it's easy to do if the head's off for refurb.
I'm seeing him about some VW business this weekend, so let me know if you want rough prices, to compare with your other guy.
The Saga continues.
We sent the injectors off for testing etc. They have come back that they are all buggered and need to be replaced[
At last the machine shop is back from holiday. However it looks like things will not be done in time for completion this month[
The body has gone off to have the engine bay re-painted[
Will keep you up to date.
MikeH
Prior to the change I was having problems with starting the car due to leaking into the cylinders, and a judder on the overrun
Here's one very similar to what I bought - same seller as I used. Being listed for Ferraris and Mercs, they should flow enough for a 911, provided the thread on the end is the right size to fit the fuel pipe. I can lend you an old golf one if you want to compare sizes.
http://cgi.ebay.co.uk/MERCEDES-BOSCH-INJECTOR-201-124-126-107-129-123-460-1_W0QQitemZ200127679330QQihZ010QQcategoryZ418QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
How much are you paying for yours?
