Hi
Went to take the car for a drive only to find the near side rear brake binding slightly; I would appreciate thoughts and guidance.
I think this is a job I could do myself, i am '3 out of 5' handy albeit I have not completed a task like this before (I have done many standard pad/disc changes on other cars). It would also save the trailer to my usual garage as its 25 miles away.
The existing caliper is about 10 years old but not done so many miles in reality, it actually looks pretty fresh. So would it be worth trying to do a caliper repair or in reality is this often a short/medium term fix only and best to just replace the caliper complete? Is a caliper home refurb reasonably straight forward? I have most general tools but no air line (i saw a few videos suggesting an air line is good to eject the pistons). Is it reasonable to just repair the single caliper only?
On refit, I would get a pressured brake fluid bleeding kit which seems the best method. Again, any comments from out there on whether this is a relatively straight forward process to bleed the small amount of air in the new caliper/nipple area having clamped the flexi to complete the job? Recommended brake fluid for the top up?
The other option I guess is to just buy a new refurbed caliper.
The rear pads/discs seem fine, only travelling a few miles since noting the binding was happening, so i assume its reasonable just to continue to use these but again just to check in case there is a concern; same comment for the offside brake caliper that seems ok, i assume ok to not touch this side?
(Anyone handy living around the Princes Risborough area would be prepared to give me a little help in exchange for a bacon sandwich is the other thought )
Sorry for the series of questions, just trying to focus on the best repair before getting into the finer detail, thanks in advance
Darren
Darren
