3.0 944 turbo
- Thread starter pauly
ORIGINAL: nick_968
ORIGINAL: pauly
ORIGINAL: TTM
The right way to build a 3.0 is the same way as to build a 2.5 - either build it the way Porsche did, underpowered but unburstable, and it will go to the moon and back, or take the chance to make it a decent performer and risk having issues. It's as simple as that.
What about the turbo engine with an S2 crank etc for 2.8 ?.
Its a good solution but not a true 3.0. Depends what you want but certainly nothing wrong with it from an engineering point of view. Andrew Sweetnam built a very nice 2.8 that made some strong numbers a few years back that left many a fast car wondering which way it went on track.
For the sake of an S2/968 crank assy and some suitable pistons I cant see a reason not to do it if you wanted to keep the original block and head.
ORIGINAL: pauly
ORIGINAL: TTM
Yes. For the record this is most likely the way I would go if I ever had another 944 turbo. You can do it but you need custom pistons or the pistons come out the top of the bores!
Nick, yes thanks I meant water way not oil way sorry. As for the 3.0 vs turbo block. I can see there are arguments for both but I personally have more faith in the turbo block from my experiences. As I said above I would go for a long stroked turbo next time. Low end torque closer to a 3.0 than 2.5, capable of 400hp (which is as much as most run from their 3.0 cars) but much closer to the 2.5 set-up and easier to build.
ORIGINAL: TTM
So what are your plans Pauly?
No definate plan Thom, like I've said if the block/head turn up for the right price I'll start a build, if not I'll save a shed load of money and aggravation.
944 man
ORIGINAL: u63af
I have a 2.7 head already. Can I use the can out if this or do I need turbo cam? Take it all I need to do is have the exhaust valves of a turbo put in?
The valves in the 2.7l 8v head are larger than in the previous 2.5l engine.
ORIGINAL: 944 man
ORIGINAL: u63af
Just the inlet valves I think.
ORIGINAL: DivineE
ORIGINAL: pauly
ORIGINAL: TTM
What makes you favour the 2.5 block other than the theoretical arguement, did you have a bad experience with a 3.0 turbo block?
TTM
Well-known member
What I can say is that my 2.5 clearly didn't provide the bold thrill of the 3.0 in terms of power delivery.
To describe the feeling, the closest image I can think of is that of a prehistoric human orgasmically planting a big axe into a mammoth. Stupidly enjoyable in a very primitive, electrifying kind of way.
The road to making a good one can be long and painful depending on what is done with all the information available, but if it was just a matter of money where would be the challenge?
ORIGINAL: TTM
Well said. Its a well trodden path nowdays but even then few get it right, first time if at all.
ORIGINAL: TTM
Hmmmnn, not sure I want to be £15k + into a car worth a few k less.
ORIGINAL: pauly
ORIGINAL: TTM
Except for those who buy a sub £1,000 banger with a view to never opening the bonnet, running it 'til it stops, and then breaking it, almost everyone is going to be a lot of money into a car which worth at least a few K less than what they've spent*. A 944 can't be expected to be any different.
ORIGINAL: Lowtimer
ORIGINAL: pauly
ORIGINAL: TTM
Depends how you buy, after owning one 3 years I could remove most of what I've added, refit original bits and I doubt I'd be a bag down.
TTM
Well-known member
ORIGINAL: pauly
Yes but you will have a car able to copiously embarass others worth 3 to 4 times as much as your car + the investment.
Putting it all together at the back of a uncomfortable garage adds a rather priceless sense of satisfaction.
As I said earlier, it depends what floats your boat. If you could afford to pay someone to do it, the flavour would not be the same, to me at least.
The Oedipus comment went well above my head I must say!
ORIGINAL: pauly
ORIGINAL: TTM
Looks like you have come to the right conclusion then....dont build a 3.0 turbo! At least not a bells and whistles version. Others such as James O have done it for a lot lot less and probably less than a 2.8 built by someone else.
