2012 MOT Rules
- Thread starter JamesO
Neil Haughey
Peter Empson
This does sound like the start of a Europe wide TUV type standard and whilst this may keep some disasters off the roads it will make modifications far more expensive than they currently are. I for one hope that we don't get such draconian measures.
Suffolk944
Moderator
ORIGINAL: sc0tty
Oh dear, 97% of the 944s owners on here start to worry ! No worries for me though [][
Have you opened the ecu to check?
DivineE
From what we currently know there are no restrictions in this country on tuning providing the vehicle passes the relevant emmission test ,both at MOT time and any subsequent VOSA road side checks.
However there have been ongoing problems where some OEM have stated they own the software in the ECU and it always remains theirs even when you purchase the car and they will not allow it o be modified. Also on newer cars the taxation rate is based on OEM declared emmission levels / economy .
It would be difficult to make existing legal cars illegal, if they did you and many others would feel extremely upset - which at minimum would lose the government votes (not that that worries the unelected EU). There will have to be ways around it even if it means an SVA type super MOT - I doubt it will even get to that though, how much many is the tuning industry worth in the UK? How much tax does that generate?
Tony
Unless it's a means of spotting 'modified' cars that don't have their modifications declared. But this doesn't really work either; there is no means of 'declaring' modifications to the DVLA and no central register for them to be noted on. And, if this is the case, why the hoo-ha about just ECU changes; what about engine swap modifications, different camshafts, cylinder head work etc etc etc?
Don't agree about the vehicle tuning industry being big enough to make this a vote-loser in the UK. UK tuning business is tiny, and even then it's employees will vote for reasons other than the structure of the MOT. It may be a vote-loser for other reasons, but not this one.
You make good points about there being no safety or environmental case for any such restrictions, but sadly politicians often try to restrict our freedoms on spurious grounds. In the end, if something is banned in Germany, and Germany currently being the paymaster of the EU bail-out programme, it is likely to end up being banned everywhere in the EU as the Germans will be the strongest influence on the EU-wide standardisation programme.
Germany has much more strict rules on all things motoring, especially car modifications. I could believe that such a test will be to ensure that no modifications to a car there can go unnoticed. I think I am right in saying that all modifications to a car are listed by the tester at the time of their annual TUV test (MOT-equivalent), so ensuring that all apparently invisible ECU modifications are tested for and listed as well simply makes things complete.
To introduce such a test here in the UK, when any other modifications are ignored at MOT time would be ridiculous in the extreme. I know this doesn't mean they don't do it, but that doesn't make it any less ridiculous!
Customers instead of employees - maybe, but what proportion of cars on the UK roads are modified? 2%? Less? Assuming it is 2%, that's 2% of car owners, which will be less than 2% of voters. And I doubt that this issue would be the only thing that affects the way that those 2% vote - sure, it will be a factor, but not the only factor.
Not being querrulous, but I think the political angle is over-stated. However I do strongly agree about your 'control' comment - that's much closer to the mark, I suspect.
TTM
Well-known member
Bottom line is have a clean car, behave on the road (=don't attract attention, especially of the authorities), don't ever get involved in an accident with severe injuries (otherwise the insurer will have the right not to cover you in case your car is "much" modified) and you should be fine.
