2.7 Engine reliability upgrades
matthew.saunders1
Morning 2.7 devotees! I'm looking for some tips & advice please around improving reliability of the 2.7 engine.
My 1976 MY (911 2.7 with 915 box) is due to go into my specialist's garage in January to have the engine out for some 'routine' maintenance & also for some "reliability upgrades".
The engine is running well (about 65k miles on it), but does have some minor oil leaks, so I expect all points of actual (& potential) leakage will be dealt with...gaskets/seals/pipes etc
In addition to this I wish to upgrade a couple of things to make the engine more reliable. First & foremost is to upgrade to the 'oil-fed' tensioners that were fitted to the later Carrera 3.2. I understand from many sources, notably the 2.7 buyers guide here, that this is 'must-do' upgrade for the engine.
I also read that another point of failure can be the head studs, which can be alleviated by the Dilavar options on the market??
I would appreciate any guidance regarding these issues/upgrades. I see Design 911 have oil fed upgrade kits. But are others available &, if so, any recommendations for which one to go for. Also, would it be wise to change the Cambelt chains as well?
Regarding the studs. Again, any recommendations? Note that I only use the car on the road & driving style is 'spirited' at best. I have no plans to race it.
Lastly, anything else anyone can recommend that I should consider to do to improve reliability whilst the engine is out?
Note, I will also be changing the worn starter motor & will also upgrade the alternator, as I intend to fit electronic air-con (Classic retro?) at some point.
I also plan to upgrade the 5 blade fan to an 11 blade fan, replace the long intake & return pipes & also adding an oil cooler to the system as I intend to drive in Europe in the summer.
I also plan to change the exhaust, ditching the heat exchangers & fitting new manifolds with a 2 into 1 (Dansk?) SS silencer. I assume it's preferable to do this whilst the engine is out?
Appreciate this is quite a long thread! But any advice/recommendations/do's/don'ts etc will be gratefully received!
Get the engine tuning book by Wayne Dempsey (eBay etc).
All your questions are answered in the modification section.
Thank you once again 🙏 Order just placed!
Got the book, interesting/informative read. Based on his recommendations for essential work I will need a specialist 911 engineering shop that can handle precision work such as strengthening the case (case savers/uprated studs). I wonder if you can recommend someone? Location not critical, but prefer Southeast (I'm near Heathrow). Thanks
Sorry, me again..
I would approach Angus at Greatworth Classics by Silverstone race track or Mike Champion at MCE in the Cotswolds. Google will get you the contact details for both.
MCE is the designated expert for early 911s, I know them both, imho top people.
Sorry, me again..
Thank you. No need to apologise for contacting. I'm very grateful for your responses! From their websites they look as though they offer similar services, but since MCE are a designated early 911 specialist it sounds like they would perhaps be best for what I need around magnesium case-strengthening?? They are also closer! Would this be your read, or is it a case of either/or?
Actually, just noticed they are both in similar location in Banbury. So worth a trip to see both!
Yes, a visit to both would be good. Settles the mind and you know far better who you are dealing with.
Greatworth is a larger operation overall, Sam is the senior engine/gearbox builder and has done some work for me on my race gearbox, so have first hand experience. I've been there 5 times.
Angus (the Boss) is busy, so pre arrange a time etc.
What you see on the web site is what is there.
MCE has a strong tech background but a smaller operation, not a bad thing imho.
Have met Mike several times most recently at a special 'early 911' meeting at the PCGB centre this year. He is very particular about the mag cased engines and what can happen on these old delicate engines, magnesium is not the best metal over time.
I have not been to MCE but a good '911 friend' has for various purposes and he is very happy with the results, and he is very picky!
I would say safe hands in both cases.
Neither do their own machining but will have proven contacts for the work (possibly the same places!). Both re-assemble on their own sites.
Understanding the facts in the Dempsey book will help a lot in discussing things.
Hope this will get you going.
Graham.
Graham.
Graham, Thank you so much for taking the time to reply. Recommendations from those with first hand experience is invaluable, especially to a relative novice such as I, and I will be making tracks to Banbury in the next few weeks! Much appreciated again. I'll let you know what I do. Cheers Matt
Graham.
Graham, just to let you know I popped up to see Mike earlier this week and was very impressed with him and his set-up. Booked in for a 911 health check early next year.
So grateful for your recommendation. I’m definitely in the right place for the next stages of my 911 journey!
Many thanks and have a great Xmas! Matt
