Evening all,
Any help with this problem would be appreciated.
Recently developed problems starting the 944 after we ran the fuel down to its reserves. Car cut out on the way to the petrol station. Obvious first step was to top up the tank, 10 litres from some jerry cans later and still no start. Checked the fuel pump was working using the wire loop in the DME socket trick, pump whirled up fine, also would of removed any air bubbles that might of formed. Still no start. Checked the spark plugs and they didn't seem to be sparking too well so changed all plugs, distributor cap, rotor arm and ignition coil (all were on to-do list anyway). Left the car for a couple of days, went back and it started up fine, sounded very smooth but cut out after about 2 minutes. Checked the fuel is reaching the fuel rail and thats fine, the engine is also turning over well but just not catching. Checked all appropriate plugs and sensors have clean connections. Went to start it again tonight and had it running nicely for 10 minutes until it cut out.
Heres what I think the problem might be: Because the fuel ran right down to its reserves some gunk may have entered the fuel filter. When the car sits unused for a few days the fuel has time to filter through to feed the engine, but when the engine runs for a decent period of time the fuel can't flow fast enough to feed the engine, hence it cutting out.
Does this sound reasonable?
Josh
Josh
