Indi9xx
Hi chaps,
Not wanting to barge in, but thought I would add some clarification.
1. I, Jon Mitchell, can be wrong, am sometimes wrong, am human, make mistakes and if anyone ever thinks I am wrong they should feel free to pull me up on it. Otherwise, I will continue being wrong, which isn't good!
2. A Thatcham standard for anyone that's confused by "Cat1" or "Cat2" is as follows. Cat1 means it's a Thatcham approved alarm and immobiliser. Cat2 means it's just an immobiliser.
3. No Porsche alarm, as far as I am aware, until about 1995 is Thatcham cat1 approved, even if the H&P immobiliser is fitted to supplement it. This is due to several ways in how it works. Not a shortfall of Porsche, as in its day it was a good system.
4. For an immobiliser to be Thatcham Cat2 on the car, it needs to be an approved cat2 system and installed to Thatcham and VSIB standards and recommendations.
5. 90% of H&P Porsche installed immobilisers break the standard of install due to several points. Most importantly it needs to be installed so that no wires are wired into the ignition barrel switch. Not the power wires, ignition signal, or to cut circuits. Even if the H&P had 10-circuit cutout and just one circuit went to the ignition barrel, it would brake the installation standard. Porsche can not be blamed for this, as when they were installing the units the standards had not been written and they were installing them to a 10 times higher standard even modern installers do today!
6. If the 1980's and early 90's systems from H&P are approved is a slightly grey area. Technically they meet the criteria of 2 or more circuits immobilised, it has an armoured box, wires are not colour coded and they will auto self-arm. So essentially they are good systems and they do meet standards. Thatcham retrospectively approved specific 1993 (I think) onwards H&P immobilisers as CAT2. Although I think the H&P fitted before 1993 has the same model number, its grey area because if the install and system was pre-1993, I don't think it's covered. (I could be wrong)
7. 1980's and 1990's H&P systems are antiques in terms of age. They are beginning to fail and I am seeing an increasing number of failed units causing recovery trucks to turn up outside my workshop with a non running Porsche on the back.
So the main issue is the install, in particular the ignition barrels being used. The problem with this is it makes the life of a potential thief easier, as the common practice by lowlife is to smash a window, open the door, climb into the drivers seat, reach behind the dashboard and pull out the ignition switch so he can manually turn it to start the car or hot-wire the contacts...
If the car is immobilised/installed to Thatcham standards, he will get no joy, see no wires tapped into and he knows he has a job of finding an immobiliser ahead of him, which could be anywhere, so potentially he may need to rip the entire car apart to find the box or the cut circuits.
If the car is not immobilised to Thatcham standards, even though it has a cat1 or 2 system, and he sees any wires on the ignition barrel, he knows that he just needs to follow the wires and they will lead him to a nice black box and wires leading to cut circuits. He does not care about your interior, he does not care too much if he does not succeed and makes a mess off your wiring in the process. But he will have a head start in any case.
The last thing is insurance loss adjusters. Often called "Engineers" or "assessors" to make the insured feel the chap isn't hired to try to find a "get out" for the insurance company. Depending on how much he wants to reduce liability, they will look for any excuse not to pay. Even if the car was in an accident, anything, which makes the car not as insured, will give them a get out. This could be non-standard wheels which are not disclosed, poor condition of safety items (worn out brake disks etc) or a security product which isn't as described in the policy. If an assessor looks behind the dashboard and sees wires on the back of your ignition switch, which led to an immobiliser, you're in trouble.
Luckily they rarely go this far unless you have just planted your 944 into a into something expensive and its worth their extra time to find an excuse why you should be classed as uninsured.
At the end of the day, you may be one of the 10%, which has a better install, which meets the standards. But on the other hand you may be one of the other 90% who have H&P wires leading to your ignition switch. Or you may be one of the really unlucky ones who may find yourself in the middle of nowhere with an immobiliser that has picked the worst time to give up the ghost.
All the best
Jon Mitchell
www.9xx.co.uk
