1978 - 930 wheels
Nick Paul
Hi any idea if 8J x 18 ET52 (fitted with 225 /40 - 18 and 10J x 18 ET65 (fitted with 285 /30) - 18 would fit my 930?
Hi Nick, these wheels will fit but you will need spacer kits both front & Rear and you may need to reduce the rear tyre width to a 265 to clear the oil pipes which run under the arch.
Spacers;
25mm front
50mm Rear
You can also do this yourself by putting the off sets into an off set calculator vs your own wheels and it will work it out for you. You will also have to divide any extra width you have by two (2) because off set ET's only takes into account 50% if the wheel rim width.
If you need more info please let me know? hope this helps regards Ian.
