1977 sport o’matic
- Thread starter Johnmeers73
If its just those gears is more likely to be the gearshift lever switch. If it's a more general problem then possible causes could be poor wiring to the solenoid, duff solenoid, poor earth to the chassis,
kinked hoses or loss of vacuum.
Only seems to do it in D1 and reverse at low speed, with the engine off but ignition on changes fine and you can here the solenoid clicking in the back of the car.If its just those gears is more likely to be the gearshift lever switch. If it's a more general problem then possible causes could be poor wiring to the solenoid, duff solenoid, poor earth to the chassis,
Sounds as though its a vacuum problem. Vacuum will be lower at low speed. Seems as though the clutch does not disengage.
The electric bit sounds ok since you can hear the solenoid. But with the engine off its more difficult to know if the clutch will disengage.
