Hello, I am new to 911 and do slowly explore my new companion. And as one can expect there are a few questions that arise which I hope will find some answers in this forum.
1. Small compartment at the front: under the front hood there is an extra little compartment which looks like it had something in it which was removed. Any idea what this is for (image 1)? Also there is an opening into the passenger compartment (image 2).
2. Drivers door: on the sides of the door are a few switches which function I have not figured out yet; there three in the front (image 3) labelled 1,2,3 and a single one on the rear side of the door (image 4)? And on the top of the inner side is a small red LED (image 5).
3. Mirror on the co-driver side: this has been added at a later stage; I have not found an option to switch from adjusting the driver side; any idea where that could be located?
4. Dashboard panel: there is an extra silver "thing" next to the wheel (image 6). Any idea what that would be for?
5. DAB radio: I have a DAB radio (image 7) and I think the related DAB antenna is on the top of the front window (image 8). Unfortunately the reception is very bad and mostly interrupted. Any idea about the cause (wrong antenna location or ...)?
Thanks.
In case the images do not show, one can right-click on the icon and select "open image in new tab" which will then show the image.
Thanks.
