10mm spacers on the front?
- Thread starter leepox
Emc sell spacers with studs but I found they caused vibration at speed so got some solid 10mm spacers for the Front by cargraphic
Could fit spacers and wheels see if you like it then do the studs after? Pulling the studs in thought hub needs opened steel nuts
Consider the effect the change in offset has on the scrub radius & handling as well as the looks [
944Scott
ORIGINAL: eddieedmo
I have some 6mm spacers going spare if you want to try them pm me your address if you do .
Nick
If Leepox does not want to try your 6mm spacers I would be interested in trying them.
eddieedmo
ok no problemORIGINAL: 944Scott
ORIGINAL: eddieedmo
Nick
ORIGINAL: T3rra
The max spacer you can fit on stock studs is 7mm, 10mm will fit but that's your choice.
I was thinking 7mm if I decided to stay with the stock studs.
ORIGINAL: eddieedmo
Nick
That would be perfect to make me decide what spacers I want!
ORIGINAL: Riverside
I have 15mm spacers on the front of mine with the original CS rims.
By any chance could you point me to where you bought the spacer?
944 man
ORIGINAL: Riverside
I have 15mm spacers on the front of mine with the original CS rims. The spacer bolts to the hub, the wheel is bolted to the spacer. Hubcentric spacers shouldn't introduce a vibration (the centre hole locates the spacer, the studs just hold it in place).
Consider the effect the change in offset has on the scrub radius & handling as well as the looks []
How does it feel Malc? Speeds up and livens up the steering at the expense of the safer handling in the event of a puncture?
Neil Haughey
ORIGINAL: 944 man
My front rims have a 65 offset so the spacer takes that back to 50. D90's & most other late 944/968 rims have a 53 front offset so it's not that much of a risk really, and if you get a puncture in any car just stay off the brakes & let the car slow down on it's own [8D]
The main reason was to put the scrub radius to the inside half of the contact patch for better feedback & initial turn-in response. The wider front track (no spacers on the rear of mine) decreases understeer (and increases oversteer) so mine is set up with a slight nose down attitude to compensate. I've never timed my car at any track so I couldn't say whether it's faster but it's more forgiving and allows me to play with trail braking to tuck the nose in on corner entry and wag the tail if I choose [
The spacers were from Jasmine I think but any reputable motorsport specialist should be able to supply them.
