“Possible R gear fault, driving permitted”
raj_28
Hi,
I’m new to the forum so a hello to all of you.
I recently ran into an issue with my Porsche 718 Boxster GTS (20 reg). As background, it’s 4 years old, done about 18500 miles, bought from an OPC and is under warranty.
I was driving north to Durham and, after about 200 miles of driving, the dash showed an amber warning “Possible R Gear Fault, driving permitted”. As it said, “driving permitted”, I continued to do so but the traffic slowed on the A1 to 40mph (roadworks) and the car started juddering and I realised it was stuck on 7th gear and about to stall. Somehow, I managed to keep it going and got onto the first exit after a hairy mile or so (you can imagine the abuse I would’ve got if it stalled in the middle of a single lane motorway). As I had to slow down to take the roundabout after the exit and the car was still stuck in 7th gear, it stalled; I was lucky enough to guide it slowly to the side, out of the way (mostly) of the high-speed traffic on the roundabout.
Safely on the side, I googled the fault with no real help other than some contributors mentioning that they had had the same issue and if the car was switched off and restarted after about 15-30 mins, the fault disappeared. In some other cases, the folks pointed to a faulty PDK. I locked the car, unlocked after 20-25 minutes and restarted but, in addition to the above message, it started showing me an additional warning “Engine control fault, Consult dealer, driving permitted”. If the R gear was engaged, the “R” light on the dash would flash without engaging the reverse gear and, if the car was put in D, the 2nd gear would engage (not the first) with the “2” flashing on the dash. I tried this again after 30 mins with the same result. Please note, prior to driving away from home, I did not have any warning lights nor during my 7-month ownership.
I wouldn’t want to go into the details of the recovery other than to state that it was rather painful and it took the recovery guys 3 days to bring the Porsche back to my OPC in the South East. Now I’ve just received a message from the OPC that they’re unable to see or replicate the issue. Go figure…
Has anyone faced this issue? Any inputs will be most helpful.
Kid regards,
Raj
Hi Raj,
Sorry to hear about your troublesome - and potentially dangerous! - issue.
I assume that your dealer has interrogated the transmission using the Porsche PIWIS diagnostics and hasn’t found any error messages? Unfortunately there’s very little that can be done other than to recalibrate the PDK software, which you could ask your dealer to perform.
Hope that you get it sorted.
Jeff
Thank you, Jeff. I assume they would’ve have plugged in the PIWIS as just looking at the dash lights wouldn’t really be appropriate to reach a conclusion. However, I’ll ask them and also pass on your recommendation on the PDK software. Need to be mindful that I don’t hurt their egos in the process :)
Thanks again.
Raj
Ha,ha! I wouldn’t worry about that Raj. I’d just ask them if - as a matter of course - they’ve recalibrated the transmission.
Good luck!
Jeff
Thanks again.
Raj
Personally - I wouldn't assume that they had plugged in the diags. No experience of that OPC and I have had good service from my local one - but I have had several issues with main dealers over the years who simply treat everyone as a liar and/or idiot. - and Audi service manager told me the stability control warning that was on the dash was caused by "whichever monkey fitted your phone kit" - where said phone kit was simply a plastic cradle that clipped into the airvent - didn't even have any wires in it.
I would suggest an email to the service manager, asking them to details the diagnostics they ran and any codes found and then ask them if the followed any of the Guided Fault Finding procedures that the PIWIS software provides for tracing faults ( sure - there may not be a G.F.F. procedure for your particular scenario - but chances are they haven't got that far.)
I would then ask them since they cannot reproduce the immediate problem and assuming they have exhausted the diagnostics procedures have they referred the issue to Porsche GB and or the mothership.
Don't let them just pretend to do stuff - ask them for the steps they have taken. Typically an investigation into a warranty covered issue goes "we will run a test and investigate, if we find a problem covered by warranty then you won't be charged for the investigaiton" - in my opinion - if they didn't charge you then they did no more than look through the window to see if there were lights on
Thank you. I had received an email from the OPC on Friday, requesting more details on the fault. I outlined the completed sequence of events as above. Haven’t heard back from them as yet. If I don’t hear back by this afternoon, I’ll ask them the questions you noted above .
Thanks again.
As an update, i received the following email from the OPC:
“Very frustratingly the warnings are not occurring now and with no permanent fault codes having been recorded in the event memory. The next step recommendations from our workshop are to carry out some road testing to see if we can reproduce the concerns. To do this, would you be happy for our workshop manager to carry out some overnight testing putting some but little mileage on the clock to try and experience the warnings with our diagnostic equipment plugged in?”
My response:
“Thank you for getting back to me. I’m happy for you / the workshop manager to carry out the testing with the diagnostic equipment plugged in. However, out of curiosity, the PIWIS (assume you’ve already done this?) has not thrown up any fault codes and nothing recorded in the event memory? That is rather strange. And nothing in the GFF procedures to track / remediate such faults?
I would also request you, and you’re the expert here, to please update the software or reset it, if the software is the latest version.
Please do let me know how the test goes.”
Will let you know the outcome of the latest round of tests.
Kind regards,
Raj
A sensible approach I think Raj, and at least your dealer does appear to be engaging with the problem. Intermittent faults are always a bit of a nightmare to tackle, but potentially yours is a safety issue which needs to be investigated fully and resolved so that you can have confidence when driving the car.
Let’s hope you get some good news. Keep us posted.
Jeff
Update:
The technician took it for an extended road test today (60+ miles per the PVTS!) and was able to replicate the reported concerns. They will now investigate further.
I’ll keep you abreast of further developments.
That’s good news. Armed with that then it’s over to them to resolve.
Not wishing to be “that guy” but personally would be looking to see what the options for a replacement vehicle are (you may not need it but the cost of providing you a car helps focus the attention on fixing yours). You could be looking at a replacement gearbox which will have a lead time and take a few days to install.
I am all for working with a dealer in these circumstances but setting an expectation and keeping them honest doesn’t hurt in my opinion.
Thanks. When my car was recovered to the dealership, I was told that I could get a courtesy car via Porsche Assist only, as cars in for recovery are not covered for a replacement from the dealership. Not really requiring a replacement, I let it pass.
Anyway, based on your suggestion , I’ve emailed the OPC to understand what my options are. In all likelihood, they might direct me to the Porsche Assist.
PS: unrelated to Porsche, received a letter from Audi yesterday on a recall for my plug-in hybrid… 2025 has commenced on a rather dour note for my vehicles :)
An update to those who may be interested:
The car is still at the dealership (4 weeks in). Initially a wiring loom was ordered from Germany but that didn't fix the issue. A technical report was subsequently sent to Porsche GB and they recommended to replace the oil sump, shims, and associated fixings. I understand these have been received last week but as of Friday, the dealership was waiting for a "special tool" to be delivered to carry out the repair. They were supposed to get back to me yesterday; I haven't heard anything so will chase tomorrow. In all fairness, they have been responsive.
It appears that perhaps Porsche haven't been able to pinpoint the issue. Meanwhile, Porsche Assist had arranged for a replacement vehicle via Enterprise.
Glad they are owning the problem but it must be frustrating that they are taking their time and “firing the parts canon at the car”
Not wanting to be “that guy” but I wouldn’t be surprised if there’s a new gearbox headed your way.
It’s been very frustrating, Paul, more so because of not finding the root cause of the issue. That for me does raise doubts whether I could trust this car for an extended driving holiday in Europe…which is an absolute bummer.
Hi Raj,
Thanks for the update, but sorry to hear that you’re no nearer a satisfactory outcome after a month.
Your dealer will be working under the direction of Stuttgart, but it does sound as though the parties involved are tinkering around the edges in the hope of avoiding a transmission replacement, which will be the ideal outcome for you in providing long-term confidence in the repair.
Keep at them … and good luck!
Jeff
Update:
The “special tool” was finally delivered on the 21st and repair carried out on the oil sump, etc. However, the repair has not resolved the issue. Porsche and the dealership have finally agreed to replace the gearbox (as originally noted by both Paul and Jeff in their responses above), though the dealership has been frank in stating that repairs are carried out as instructed by Porsche and manufacturers will always look to carry out the most cost-effective repair to start with.
Fingers crossed that this resolves it once and for all and I’m happy that the dealership has been responsive, though it has taken longer than expected.
A good result Raj … finally! It’s a pity that it’s taken so long to reach this stage, but as your dealer has said they’ve had to take their lead from Stuttgart; their warranty provider in particular.
Hopefully that will be the end of the matter and you’ll be able to enjoy trouble-free driving from now on, especially since the weather is improving.
Just as well that you’re covered by the Porsche Extended Warranty because a new PDK transmission probably will be at least £13k plus fitting!😳
Let us know how it turns out.
Jeff
And finally:
The gearbox was replaced, no further faults were displayed and I got the car back today...almost 2 months to the day since it broke down. Though it did take much longer than expected, I'm rather happy with the dealership that they got to the root of the problem and kept me informed (sometimes they did require a little nudge). Hopefully, I should see some trouble-free driving over the next months / years and don't have to revive this thread!
Last but not the least, my sincere thanks to Jeff and Paul for providing their guidance and support throughout this long-drawn process.
Hi,
What's the update on your car with the new gear box? Has it fixed the issue completely? I am in your shoes and my gear box is being replaced. I am trying to decide if I should keep the car or exchange it with something else. If your issue has been fixed completely, I would keep the car.
Hi Raj, Ali
it looks like i may have the same issue, like you Raj my 2019 718s was stuck in 7th on the motorway... I have an extended warranty thank goodness.
