Helpful Replycan you tell me what this brace is?
Stephenjk
Stephenjk PCGB Member
2018/03/11 22:49:37 (permalink)
I was under the rear of my car on Saturday and noticed this rusty looking brace.  The rust appears to be mostly surface, so two questions if you can help
1. what is this thing called if i need to replace it?
2. do you think I'll get away with brushing and painting it or is going to need to be replaced?
This is c4 1990 coupe.
BTW i was under there replacing the bumper supports, which i did successfully for one of the two.  The other one the screw was rusted in place so any ideas for how to remove?  i dont think i would want to get a blow torch under there and penetrating oil didnt help.
thanks
Stephen
Attached Image(s)
deano911
deano911 PCGB Member
Re: can you tell me what this brace is? 2018/03/12 09:59:12 (permalink)
Are they these that help support the shark fin side trims.
See attachment.
I recently bought a pair of new ones on ebay and had them gloss black powder coated.
There is guy reproducing them and selling them on ebay.
Dean
Attached Image(s)
Stephenjk
Re: can you tell me what this brace is? 2018/03/12 10:16:47 (permalink)
Mine are pretty much straight so I’m not sure they are the same as those.  Could they be the pipe holder 964 504 875 00?  I found these as i was searching for the shark fin support you mentioned on ebay.  These look more similar to what i have in the picture
https://www.ebay.co.uk/itm/Support-Pipe-Holder-for-Bumper-Rear-Porsche-911-964-Carrera-2-96450487500/162113047510?epid=25005568017&hash=item25beb0cbd6:g:jKoAAOSwd4tTtBDZ
Dekker
Dekker PCGB Member
Re: can you tell me what this brace is? 2018/03/12 11:32:53 (permalink)
Stephenjk
That looks like the part. When I refurbished the rear end I bought some stainless steel tubing and flattened the ends in a friends hydraulic press.
The only trouble now is the paint gets blasted off by the rain and road grit leaving it shiny, but no rust.
With regards to the stuck screw, drill it out. Often they will free themselves in the process from the heat generated from the drilling.
post edited by Dekker - 2018/03/12 11:39:23
David Bladon
964 Register Secretary
964 C4 Cabriolet Cobalt Blue
964 C2 Coupe Marine Blue
SAAB 900 T16 Ruby 1993 all weather
mcgc0
mcgc0 PCGB Member
Re: can you tell me what this brace is? 2018/03/12 11:58:26 (permalink)
'Support Tube' [Part # 964 504 875 00] is what it looks like. A bracket to support a heat protection piece/shielding. Is your C4 Turbo Bodied?
Remove if you can and wire brush/sand what you can of it. If in reasonable condition then maybe Kurust it and apply a heat resistant Hammerite paint coat. Otherwise, as it's pretty much a straight angled bracket, it should be relatively easy to make up and powder coat.
'90 964 C4 Velvet Red
'94 968 Sport Gaurds Red
'90 964 C4 Slate Grey
'03 Focus ST
'02 Focus ST
Stephenjk
Re: can you tell me what this brace is? 2018/03/12 12:07:31 (permalink)
Thanks David I‘ll give that a go.
Ray
Ray PCGB Member
Re: can you tell me what this brace is? 2018/03/12 12:14:54 (permalink)
Item 19?
Is this the type of thing? I had some similar on my 3.2.
Ray
Dekker
Dekker PCGB Member
Re: can you tell me what this brace is? 2018/03/12 14:46:41 (permalink)
No Ray it's the support bracket #17
Attached Image(s)
David Bladon
Ray
Ray PCGB Member
Re: can you tell me what this brace is? 2018/03/12 14:48:42 (permalink)
Dekker
Great, I got the bracket # mixed up.
Ray
Stephenjk
Re: can you tell me what this brace is? 2018/03/12 15:34:32 (permalink)
mcgc0
Thanks. No not turbo bodied, just normal c4.
Stephenjk
Re: can you tell me what this brace is? 2018/03/13 21:16:54 (permalink) ☄ Helpfulby watt400 2018/03/28 14:18:20
I would suggest you start a separate thread for that.  I dont know the answer but you'll likely get more of a response on it's own topic.
T911UK
T911UK Guest of the Club
Re: can you tell me what this brace is? 2018/03/14 08:10:59 (permalink)
The answer is no so maybe dont bother
www.type911.co.uk
993 Turbo
911 SC Targa - Backdate to 1972
911 SC Targa - Minted
Cayenne Turbo S
Boxster 2.5
colin129
colin129 PCGB Member
Re: can you tell me what this brace is? 2018/03/14 14:13:31 (permalink)
There is 'how many left', but that will only tell you how many of a certain type of car are still registered in the UK, so not really what you want.
Colin
964C2 Coupe 1990 Granite Grey 159K
944S2 1990 Guards Red - Gone & very sadly missed
BMW 318D - slow, slow, slow coach. Most disappointing car I have ever owned.
Gordon Attar
Gordon Attar PCGB Member
Re: can you tell me what this brace is? 2018/03/15 12:32:53 (permalink)
Ref screw if you can get pliers to hold the metal bracket that the screw is screwed into you should be able with force be able to undo plus more penetrative oil first.
Gordon
964 C2 Cab, 996TT
ex cars 944S2, 964 Targa, 944T, 993 Cab, 993 Targa, 993 C4S, 993TT, 996TT
Stephenjk
Re: can you tell me what this brace is? 2018/03/16 09:26:40 (permalink)
Thanks for all the advice. I bought 2 from carpoint.de for £64 delivered, which I think is pretty good and much cheaper than design 911. I also will try plusgas on the screw and it that doesn’t work will try the tips below. I have been using just penetrating oil but apparently plusgas is more effective.
Stephenjk
Re: can you tell me what this brace is? 2018/03/27 08:08:32 (permalink)
Partial success at the weekend.  I got the first bolt out okay the higher of the two.  The second bolt was stiff and came out about half way before snapping.  Luckily it snapped near the head so it left enough of the body for me to get the new support part with a nut holding it in place.  Any suggestions on removing the bolt thread?  I was thinking maybe a nut screwed on might work But didnt seem to work (i was also bit wary about force to apply).  There isnt enough of the thread to put 2 nuts on to unlock it that way.
Dekker
Dekker PCGB Member
Re: can you tell me what this brace is? 2018/03/27 13:01:29 (permalink)
Try not to use too much force. I tend to screw it back and forth dowsing it with Plusgas each time I screw it in. In your present circumstances your only option I can see is using mole-grips on the stub using the technique above.
Are you any good with MIG welders, you could weld a nut on the end.
post edited by Dekker - 2018/03/27 13:04:09
David Bladon
richardjjs1
richardjjs1 PCGB Member
Re: can you tell me what this brace is? 2018/03/27 14:02:30 (permalink)
Get a price from Porsche PDC First - Often very reasonable
Porsche 987 Boxster 2.7
Now Gone:
Porsche 986 Boxter 2.7
Porsche 911 Carrera 3.4 Cabriolet Carrera S
2001 - 2011
Various BMW Convertibles
1997 - 1999
1991 - RR Audi quattro
1989 MB Audi quattro
1981 - WR Audi quattro
T911UK
Re: can you tell me what this brace is? 2018/03/28 13:54:51 (permalink)
£44.06 from OPC so you got a bargain!
www.type911.co.uk
993 Turbo
Cayenne Turbo S
Boxster 2.5
Stephenjk
Re: can you tell me what this brace is? 2018/03/28 14:21:35 (permalink)
Yes that is second set of parts from carpoint.de i have bought via ebay. I have some brake backing plates too at half the uk price.
What i really need is a cheap place to buy bolts and screws.  I've been using design911 but they are expensive plus charge courier prices for everything so few bolts costs an arm and a leg.
Btw i inon used one of my supports if anyone needs one.
Porsche
Lockton
Silverstone Auctions
Pirelli
Pirelli
Oracle Finance
Archant Dialogue
HFMC Wealth
Cornbury House
Cotswold Business Village
London Road
Moreton-in-Marsh
Gloucestershire  GL56 0JQ
Call us: 01608 652 911
