Rutland 2017 March 12th
- Thread starter edh
Tommys86
I'm up for Rutland - I was unable to attend last year!robwright said:Same as. Getting some body parts painted over winter.
However my body work does need some TLC - saw your comments Rob, you being a local man to Peterborough region is there a particular business you use / recommend?
Tom
Tommys86
Tommys86 said:I am indeed! Hampton more specifically - I'm starting to worry if extensive work is required or get away with bit of cutting out, plus the car has had a respray (previously) which is noticeable in a few areas..... plus the front bumper is starting to fade.... I've got a few "freer" weekends coming up so might drop you a text and take the car for a blast up the A1? Depending on your reaction I might judge whether I'm worthy of a Rutland outing!
All 944's are worthy sir....last year was my first and it was a great meet, SWMBO loved it too so win win all around...
Pete
robwright
As Pete has said all cars are welcome and indeed come. No worries any time you want to pop over. Just text meTommys86 said:I am indeed! Hampton more specifically - I'm starting to worry if extensive work is required or get away with bit of cutting out, plus the car has had a respray (previously) which is noticeable in a few areas..... plus the front bumper is starting to fade.... I've got a few "freer" weekends coming up so might drop you a text and take the car for a blast up the A1? Depending on your reaction I might judge whether I'm worthy of a Rutland outing!
My good mate Dave has spent the last couple of months fettling his newly acquired even older tub and he should be good to go too.
Last year was my first trip and it was probably the biggest gathering of 944's I have yet seen.
The good thing is soap and water are cheap but dirt costs nothing.
Zeusy.
It's a very simple form/process and I'm happy to explain how it works...
