Quarterflash
Hello Everyone
Some of you will already be aware of my 948. There is a story behind it but for now here is a brief and some photos.
The car (an 89 250bhp turbo with M030) was bought with the intention of fitting the Chevrolet engine because, being a late model turbo it already had the right brakes and gearbox ratios to cope with 300 hp (224 kW) and 340 lb·ft (461 N·m) torque.
A conversion kit was imported from Renegade Hybrids in Las Vegas (http://www.renegadehybrids.com) and that was used as the basis for the conversion. The actual engine used is a 350 ci (5.7 litre) LT1 from a 1995 Corvette which has alloy heads and an iron block. Subsequent Corvette engines (LS series) are all alloy which has less effect on the weight distribution although the LT1 is OK. Fuel economy - don't ask.
The car is in shakedown at the moment (June 16) and there is work still to be done but for now at least I get to drive it.
Thanks to Pro-9 for all their hard work and to my understanding wife.
The wheels are Boxster fitted with Toyo Proxes T1 Sport.
