jellytott
MY PROBLEM
Oil coiler and OPRV replacement,, here goes.
Done the following in paragraph below, completed works and started her up, the oil filter seal failed within seconds pushing out oil at high
pressure everywhere, hoping it was just "the oil filter" not tightened up correctly. I removed and seated oil filter seal again, started up
same,,, tried another oil filter and same again I lost 4 ltr of oil in no time at all my inspection pit looks like an oil bath and me
absolutely p*ssed off too.
Oil guage showed 4 to 5 bar (normal) when the oil filter fails it does go with some force and squeel too with the resulting pressure I assume and hope, I have only run it for seconds each time.
REASON WHY
Started with that common oil leak LHS (PAS pump side of engine) the clues,,, oil puddles when left parked, also covers
the PAS pump with oil plus smells oily when hot after long runs. The quick fix of tightening up the 4 housing bolts failed to stop the leak so decided to get it sorted. I knew and researched parts and technique, so the 944 had 2 types of OPRV early and late *** (the early Oil Pressure Relief Valve made up of 3 parts nut, spring and piston these early types basically covered 83 -86, then after this early type a new "one piece OPRV" covering 1987 and some 924S this 2nd one piece replacement also now replaces the early 3 part OPRV piece too).
I followed the plans available from various sources and ordered parts from the Dealers, plus sourced the allign tool off the for this forum
too from a helpful forum member. Knowing there's 2 types of OPRV these are year bound I worked out mine being a 1988 was the later
type being the larger 24mm nut OPRV requiring just the crush washer (part 34) and oil ring (part 45 or 45A), along with new oil cooler housing seal, shim washers and oil cooler orings too.
So, I have since found out there are infact 3 types of OPRV,s
1- the smaller nut type (3 part type which is N/A)
2- a 24mm OPRV (1 piece) part no 944 107 035 11 I beleive this requires tool 9215** this one I have and used.
3- then a 24mm slightly longer OPRV (still 1 piece) part no 944 107 035 01 alignment tool rquired 9262/1
Basically, I was completely unaware there are in fact 2 type's of 24mm late OPRV and 2 type of allign tool too, I've used the slightly shorter allign tool 9215 for the longer OPRV part 944 107 035 01, of course a double wammey when used the shorter 9215 tool allign in the Cooler housing here so using it appears things where "nice and true" for the OPRV to site into the cooler housing and Engine block, I only felt a bit of presure difference when I inserted the complete valve and just thought the o-ring was pushing home...how wrong I was!
My question to those clever mechanics or those with a brain the size of a planet!
1) have I caused teminal damage to the engine??
2) I have removed the OPRV, the o-ring isn't damaged but half way along shaft it is slightly polished I suppose when inserted into cooler housing/block not being true in shaft/bore to housing.
3) Have I damaged the existing OPRV valve?
3) Anyone got the longer 9262/1 allign tool for the longer OPRV I've got?
Thanks in advance
John
presently very very feed up :-(
MY PROBLEM
REASON WHY
Thanks in advance
John
