The Porsche Cars website carries a Classic Product News section that lists remanufactured Genuine parts, the files date from January 2013 to June 2015 and contain parts for all 924 variants. I have extracted (the best I can) the relevant parts for our cars from the lists - please refer to a Porsche Centre or specialist before ordering parts for your car - this list is for information only. http://www.porsche.com/uk...hy/features/downloads/
January 2013
No items.
February 2013
1. Oil sump gasket 94410120502 - 924 S (1986–1988), 944 (1982–1991), 968 (1992–1995)
2. Tool bag with contents 94472102705 - 924 (1976–1988), 944 (1982–1991), 968 (1992–1995)
3. Front seat cover left 91152135902 - 911 (1974–1986), 924 (1976–1988), 928 (1978–1986), 944 (1982–1985)
4. Front seat cover right 91152136002 - 911 (1974–1986), 924 (1976–1988), 928 (1978–1986), 944 (1982–1985)
March 2013
5. Control valve for K-Jetronic 94411042900 - 924 S (1986–1988), 928 (1983–1986), 944 (1982–1991), 964 (1989–1994)
January 2014
6. Brake pad repair kit 94435195102
924 Turbo (1979–1983)* 924 S (1986–1988)* 928 (1978–1982)* 944 (1982–1989)*
For the regular maintenance of your classic: the brake pad repair kit that stands out for its quality. Because characteristic Porsche brake pads are manufactured using special tools. This repair kit can be used for the Porsche 924 Turbo from model years 1979 to 1983, Porsche 924 S from model years 1986 to 1988, Porsche 928 from model years 1978 to 1982 as well as the Porsche 944 from model years 1982 to 1989.
7. Wiper motor 477955113B 924 (1976–1988)* 944 (1982–1985)*
8. Brake pad repair kit 94435295102 - 924 Turbo (1979–1983),924 S (1986–1988), 944 (1982–1989)
9. Brake pad repair kit 92835295102 - 928 (1978–1986), 924 (1976–1985)
10. Brake pad repair kit 94435195103 - 928 (1978–1986), 924 (1976–1988), 944 (1982–1991)
11. Auxiliary headlight Left 94463140700 - 911 (1987–1989), 924 (1976– 1988), 944 (1982–1989)
12. Auxiliary headlight Right 94463140800 - 911 (1987–1989), 924 (1976– 1988), 944 (1982–1989)
13. Hexagon nut M14x1.5 90007800503 - 911 (1965–1973), 924 (1976–1979), 944 (1985–1988), 914 (1969-1976)
14. Headlight cap 477941659A - 911 (1987–1989), 924 (1976–1988), 944 (1982–1985)
February 2014
15. Adjusting ring 91533226512 - 911 (1965–1989); 914 (1969–1976); 924 (1976–1985); 959
16. Floating frame Left 94435142900 - 924 S (1986–1988); 944 (1984–1989)
17. Floating frame Right 94435143000 - 924 S (1986–1988); 944 (1984–1989)
18. M 10X75 hexagon-head bolt N 0104736 924 (1976–1985); 928 (1978–1995)
19. Crankcase 924 S 2.5 L without piston 94410096000 - 924 S 2.5 litre Engine M44.01 – M44.10*
March 2014
20. Pressure control valve 113955187
911 (1974–1983)* 914 (1974–1976)* 924 (1978–1983)*
The pressure control valve for the headlight cleaning system. It can be used for the Porsche 911 from model years 1974 to 1983, the Porsche 914 from model years 1974 to 1976 and the Porsche 924 from model years 1978 to 1983. Caution: It can only be used for the vehicles with the optional factory-installed "headlight washer system".
21. Upper rubber mounting 94410615503 - 924 S (1986–1988)*
Upper rubber mounting for fixing the radiator in the engine compartment. It can
be used for the Porsche 924 S from model years 1986 to 1988.
22. Engine Lower rubber mounting 94410615301 - 924 S (1986–1988)
23. Transmission Release bearing 113141165B - 924 (1976–1985)
24. Rear axle Cotter pin, 5x45 90002102502 - 356 (1950–1965); 924 (1976–1985); 944 (1982–1985)
25. Electrical equipment Flat receptacle 111971959 - 356 (1960–1965); 911 (1965–1989); 924 (1976–1988); 914 (1969–1976); 944 (1982–1991); 964 (1989–1994); 968 (1992–1995)
26. Brake disc front axle 477405083D - 911 (1970–1983); 914–6 (1970–1972); 924 Turbo (1976–1988); 944/944S (1982–1988)
27. Fuel filter 93111014904 - 928 (1978–1979); 924 Turbo/GT (1978–1985)
28. Toothed belt for balance shaft 94410221904 - 924S (1986–1988); 944 (1982–1991); 968 (1992–1995)
29. Toothed belt for camshaft drive 056109119A - 924 (1976–1985)
April 2014
30. Light switch 477941531F - 924 (1979–1985)* 924 S (1986–1988)* 944 (1982–1985)*
31. Engine Fuel filter 93011007600 - 911 (1978–1980); 924 (1976–1985)
32. Distributor rotor 93160290600 - 924 Turbo (1981–1985); 924 GT (1981–1985)
33. Spark plug 99917014090 - 924 Turbo (1976–1985); 924 GT (1976–1985)
34. Transmission Spacer sleeve 94411663111 - 924S (1986–1988), Automatic; 944 (1982–1991), Automatic; 968 (1992–1995) Tiptronic
35. Electrical equipment Sleeve 059903127A - 924 (1976–1985)
36. Spark plug 99917017590 - 924 (1976–1979)
May 2014
37. Hub cap, platinum-metallic 477601051G* - 924 Turbo (1980–1984)* 924S (1986–1988)* 928 (1978–1991)* 944 (1985–1991)* 911 (1989–1994)*
The popular center of the Porsche rim: platinum-metallic wheel hub with embossed Porsche
Crest. This can be used for Porsche models 924 Turbo, 924S, 944, 928 and 911 Carrera/Turbo, equipped with the 92836102105, 92836211501, 94436211301, 92836211701 or 94436211501 rim. The crest is produced to the highest standards using original embossing tools. The hub cap is made from forged aluminum and is perfectly coordinated with the color tone of the associated rim.A guaranteed highlight.
38. Vacuum unit 477905243 - 924 (1980-1985)*
Produced by the original supplier to the latest standards: The vacuum unit ensures that the distributor works perfectly. In combination with the distributor, the vacuum unit ensures that the ignition point of the engine is always correct, whatever the operating conditions. It can be used for Porsche 924 vehicles from model years 1980 to 1985.
39. Electric fan 94462402103 - 944 (1982–1991)* 924S (1986–1988)* 968 (1992–1995)*
40. Transmission Pan-head screw M 12 x 80 90006726802 - 924 (1986–1988)* 928 (1992–1995)* 944 (1985–1991)* 959 (1987–1988)* 964 (1989–1994)*
41. Rear axle Clamp 113411333 - 911 (1978–1998)* 924 (1976–1988)* 944 (1982–1991)* 968 (1992–1995)*
42. Wheel brake cylinder repair set 19.05 477698051 - 924 (1976–1985)*
January 2015
43. Brake pad repair set 94435195102 - 924 Turbo (1979–1983)* 924 S (1986–1988)* 928 (1978–1982)* 944 (1982–1989)*
For the regular maintenance of your classic car: the brake pad repair set which is notable for its quality. Because Porsche uses special materials to manufacture its brake pads. This repair set can be used for the Porsche 924 Turbo from model years 1979 to 1983, the Porsche 924 S from model years 1986 to 1988, the Porsche 928 from model years 1978 to 1982 and the Porsche 944 from model years 1982 to 1989.
44. Air-cleaner cartridge 94411018602 924 S (1980–1988)* 944 (1982–1989)*
45. Brake pad repair set - Energit - 477698076A 924 with rear brake drum (1976–1985)*
46. Spark plug 99917015690 924 (1976–1985)*
47. Spring seat 251609289 - 356 (1950–1965)* 924 (1976–1985)*
48. Spring seat 251609289 - 356 (1950–1965)* 924 (1976–1985)*
February 2015
49. Porsche Classic Radio Navigation System 99355941100 - 911 (1978–1998)* 91164529000 911 (1965–1998)* 914 (1969–1976)* 924 (1976–1988)* 928 (1977–1995)* 944 (1982–1991)* 968 (1992–1995)* 959 (1987–1988)*
What lies behind every classic Porsche? Famous legends. Thousands of racing victories. Countless memories. And now also a Radio Navigation System. Porsche Classic presents a completely redesigned Radio Navigation system. It combines state-of-the-art technology and classic design and is suitable for all classic models with a DIN1 slot, from the 911 F model to the 911 (Type 993), as well as for four and eight-cylinder vehicles, excluding the Porsche 356. Find out more about the new Porsche Classic Radio Navigation System in the Product Highlights.
50. Air box 94411035804 - 924 S (1986–1988)* 944 (1982–1991)*
51. Wheels, brakes Check valve 477611933A - 924 (1982–1985)* 944 (1982–1985)* 9442 (1985–1989)* 911 (1987–1989) mit LWR* 928 (1983–1989) RL*
April 2015
52. Engine Crankshaft 94410201513 - 924 S (1986–1988) 944 (1982–1989), 2 valve
53. Rear muffler 477253125S 924 (1976–1985)
54. Rear muffler 94411108301 - 924 S (1986–1988) 944 (1982–1989), 2 valve
55. Exhaust system rear muffler 477253325A - 924 (1976–1985)
56. Transmission Clutch release bearing 93111608204 - 924 (1976–1985) 924 S (1986–1988) 944 (1982–1991)
57. Transmission Clutch release bearing 113141165C - 924 (1976–1985)
58. Front Axle, Steering Ball joint, 17 mm 171407365G - 924 (1976–1985) 924 S (1986–1988) 944 (1982–1985)
59. Rear axle Drive shaft 477501103 - 924 (1976–1985) 944 (1982–1985)
60. Parking-brake cable 95142407202 - 924 S (1986–1988) 944 (1985–1991) 968 (1992–1995)
61. Accelerator pedal 827723511B - 924 (1976–1985) 924 S (1986–1988)
62. Clutch cable 477721333B 924 (1976–1985)
May 2015
63. Mirror cradle left 91173104303 - 911 (1978–1991)1) 924 (1980–1985)1) 924 S (1986–1988)1) 928 (1978–1991)1) 944 (1982–1991)1)
64. Mirror cradle right 91173104403 - 911 (1978–1991)1) 924 (1980–1985)1) 924 S (1986–1988)1) 928 (1978–1991)1) 944 (1982–1991)1)
65. Grease for grease gun PCG04311000 - 356 (1950–1965)1) 914 (1969–1976)1) 924 (1976–1988)1) 928 (1977–1995)1) 944 (1982–1991)1) 968 (1992–1995)1) 911 (1964–1998)1) 959 (1987–1988)1)
66. Air filter element 021129620 - 914 1,8 (1970–1976) 924 (1976–1985)
67. Fuel pump 94460810204 911 (1984–1989) 944 (1982–1988) 924 S (1986–1988)
68. Repair kit for clutch slave cylinder 92811690100 - 924 (1976–1985) 924 S (1986–1988) 928 (1978–1995) 944 (1982–1991)
69. Wheel bearing 99905302001 - 911 (1974–1989) 944 (1985–1991) 924 S (1986–1988) 968 (1992–1995)
70. Aluminium wheel nut 99918200336 - 914 (1970–1976) 924 (1976–1988) 928 (1977–1995) 944 (1982–1991) 968 (1992–1995) 911 (1968–2005) 959 (1987–1988) 986 (1997–2004)
71. Automatic transmission gear selector gate cover strips 477713277 - 924 (1976–1985) 944 (1982–1985) 924 S (1986–1988)
72. Rear ram protection strip 477807319 - 924 (1976–1988) 944 (1982–1991)
June 2015
73. Bleeder PCG103129A - 924 (1976–1981)
74. Screw socket 91111015900 - 911 (1972–1976) 924 (1976–1979)
75. Sleeve 93112319900 - 924 Turbo (1979–1984)
76. Transmission Feather key 90011704500 - 924 S (1986–1988) 944 (1982–1989)
77. Compensation tank brake fluid 477611303B - 924 (1980–1985) 924 S (1986–1988) 944 (1982–1985)
78. Clip 113609625 - 924 (1976–1985)
79. Shift sleeve 96442422300 - 356 (1960–1965) 911 (1970–1989) 914 (1973–1976) 924 (1976–1979)
80. Nose panel 94450303302 - 944 (1985–1989) 924 S (1986–1988)
81. Set for backrest adjustment 91152138102 - 911 (1974–1984) 924 (1976–1985) 924 S (1986–1988) 928 (1978–1984) 944 (1982–1985)
82.Engine Screw clamp 99951107602 - 911 (1965–1977) 914 (1970–1972) 924 S (1986–1988) 928 (1987–1995)
83. Engine Adjusting screw 046109453F - 924 (1976–1985)
84. Engine Adjusting screw 046109453E - 924 (1976–1985)
85. Engine Adjusting screw 046109453D - 924 (1976–1985)
86. Engine Adjusting screw 046109453C - 924 (1976–1985)
87. Engine Hose clamp 99951223502 - 911 (1978–1989) 911 Turbo (1975–1977) 924 S (1986–1988)
88. Fuel system, Exhaust system Tap screw 6.3 × 19 mm N 0138911 - 924 (1976–1985) 944 (1982–1985) 968 (1992–1995)
89. Fuel system, Exhaust system Shouldered bolt 93112319700 924 (1976–1985)
90. Transmission Hexagon-head bolt 003323699B - 924 (1980–1985) 924 S (1986–1988) 928 (1983–1995) 944 (1982–1989)
91. Transmission Hexagon-head bolt M8 × 35 - N 0102478 - 356 Carrera 1600 (1960–1965) 911 (1965–1969) 911 (1984–1998) 914 (1970–1976) 924 S (1986–1988)
92. Rear axle Hexagon-head bolt M12 × 1.5 × 115 - 90008205902 - 924 (1976–1985) 924 S (1986–1988) 944 (1982–1991) 968 (1992–1995) 959 (1987–1988)
93. Body Oval-head screw M6 × 15 - N 0141405 - 914 (1970–1976) 924 (1976–1985) 924 S (1986–1988) 928 (1983–1991) 944 (1982–1991)
94. Rivet B.4 × 32 - N 0136661 - 924 (1976–1985) 924 S (1986–1988) 944 (1982–1991) 968 (1992–1995)
95. Wiper crank spacer black 91162896300 - 911 (1974–1989) 924 (1980–1988) 928 (1978–1986) 944 (1982–1985) 959 (1987–1989) 911 (1989–1994)
January 2013
No items.
February 2013
March 2013
January 2014
February 2014
March 2014
April 2014
May 2014
January 2015
February 2015
April 2015
May 2015
June 2015
