the drain pipe by the fuel inlet is full of crud. What’s the best tool to use to push the crud out?
I’m heavy handed so are there any tips to make things easier Or less likely that I cause more any damage to the drain pipe?
If I have to buy a specific cable/wire etc, how long does it have to be? Presumably I can use the same to push through the drain pipe for the sunroof too?
