Tyre pressures
stevehaley
stevehaley Guest of the Club
2022/12/28 17:53:18 (permalink)
Tyre pressures
Has anyone else noticed that the tyre presssures per the manual dont match the over/under readings on the tyre pressure readout? Ie if you set the pressures per the manual for half load the type pressure readout on the dashboard shows them as overinflated…
1 Reply
Cherub77
Cherub77 Guest of the Club
Re: Tyre pressures 2023/01/14 08:03:20 (permalink)
Just checking that you know you can change the load in the car from half to full load with the different parameters?
