Wind noise on 964 C4
Crouseilles
Crouseilles PCGB Member
2022/08/16 07:28:51 (permalink)
we are new to  Porsche ownership and have a 1992, LHD 964 C4, it has recentlY been resprayed , bonnet / trim off etc , but now there is a wind  noise from @ passenger side door at speeds over 45mph. We can detect no incoming air when when  feeling around the door and all trim and seals seem to be in good shape and complete when comparing to drivers side  , any ideas appreciated as to cause of the noise
post edited by Crouseilles - 2022/08/16 07:35:27
T911UK
T911UK Guest of the Club
Re: Wind noise on 964 C4 2022/08/16 08:19:41 (permalink)
Are all the plastic bungs in place? I had this on a car and it was wind coming in from the door through the door cardby the opening rod, duct tape solved the problem.
www.type911.co.uk
993 Turbo
964 C4
911 SC Targa - Minted
914 1974 2.0
912 1968
356B 1962
Cayenne Turbo S
Boxster 987 2.7
Stephenjk
Stephenjk PCGB Member
Re: Wind noise on 964 C4 2022/08/17 07:49:07 (permalink)
Can you get someone to sit in passenger seat with tissue to move around door to check door seal?  I had this from drivers side door seal and there was nothing visible.
mcgc0
mcgc0 PCGB Member
Re: Wind noise on 964 C4 2022/08/17 10:18:20 (permalink)
From the outside looking down towards the passenger door from the wing/headlight, does the door panel (where hinged) sit slightly proud of the wing? If your door to wing panel is not flush this often creates wind or 'whistling' noise. Also look at the very top corner of the window frame (it's the only frame corner!) - does that seal against the door rubber? Sometimes there can be a very small gap where there is marginal or no seal at all.
Good luck
post edited by mcgc0 - 2022/08/17 10:20:09
'90 964 C4 Velvet Red
'94 968 Sport Gaurds Red
'90 964 C4 Slate Grey
'08 Golf Mk 5 GTi Black
colin129
colin129 PCGB Member
Re: Wind noise on 964 C4 2022/08/20 12:30:54 (permalink)
I have a similar whistling noise, get someone to sit in the passenger seat & when you hear the noise, push at various places along the door/window seal.  At some point, the noise will probably disappear.
Colin
964C2 Coupe 1990 Granite Grey 159K
944S2 1990 Guards Red - Gone & very sadly missed
BMW 318D - slow, slow, slow coach. Most disappointing car I have ever owned.
Crouseilles
Re: Wind noise on 964 C4 2022/10/12 09:22:34 (permalink)
thanks for all the replies , they solved my problem - wind noise solved with duct tape on passenger side door where these should be an oval plastic bung & installed a new door seal.
drove to Greece and back with no issues
mcgc0
mcgc0 PCGB Member
Re: Wind noise on 964 C4 2022/10/12 09:27:28 (permalink)
Well done. Greece and back.. what a great run that must have been.
