Any one interested in a set of Goodridge braided hoses for a 997.1. I have changed my mind about fitting these , brand new in box £50 delivered. I think they will fit a variety of models , I will check the box. Though I would ask here before I use ebay.
Goodridge braided hose 997.1
- Thread starter stephenowen
Hi Stephen - Fitting these on mine are on my list at some time. My question is why did you change your mind?
I use a specialist for my work , I have got to known him quite well. My pipes are okay , no issues. He did say the joining nuts are buggers to remove. He recommended that I would need the front two small sections if he installed. He said they never fit properly and rattle and work loose from their holders. One of the rear brake pipes , if he damaged it or it needed replacing , which it doesn't, its an engine out job to replace. Luckily mine are fine with my coolant pipes.
Appreciate that, I think I will leave well alone until the solid pipes actually need changing, they were done only three years ago and are fine. Plenty of other things I want to do until that happens!!
No worries , I noticed the 997 secretary wrote a piece in the magazine about his costly bill replacing his rear brake lines this month, glad I could help and I wish I had spoken to my specialist before I purchased the pipes.
