I have been experiencing random faults with my PCM unit in my 981 Cayman S since its MOT in March. Nothing was apparent during a warm up drive shortly before the MOT, nor on my drive to the Porsche Centre for the MOT. It would have been driven from the Porsche Centre to an offsite independent test centre.
I think the AM radio was on when I collected it. I would not usually use that wavelength but has defaulted to it since. But technicians do sometimes change things.
The car is kept parked in a dry garage. I noticed a strange noise when I was using the workshop equipment and eventually realised it was coming from the car. The AM radio had switched itself on with no key in the ignition. I had to get key to turn ignition on and off to switch PCM off. This was the first sign of anything wrong with the PCM.
During the first outing since MOT I noticed strange noises from dash area shortly after leaving home. I realised the AM radio had turned itself on again. Stopped to rectify but the buttons didn't seem to be working correctly. The PCM also switched itself off several times and rebooted, each time with radio back on.
Although the car was registered in 2016 and is five years old the use of only 9300 miles is equal to less than one year and I shouldn't have a problem of this kind.
Porsche Centre said they don't disconnect battery or touch anything when service is only MOT. They had no suggestions except to bring car in for them to run diagnostics. I wanted to do some more checks myself first. But with their experience of servicing so many cars they must have some knowledge about this fault.
Two further drives were completed and nothing unusual noted.
Then I drove to Goodwood for a PCGB track day. All okay in the morning. Used the screen, with audio turned off. On way to filling station after lunch the PCM remained off and I couldn't turn it on. Afterwards it was on and off at intervals during the afternoon and on the way home. It seemed to be getting worse!
Back in the garage since then, with a CTEK charger in use, the PCM was working or not at intervals. Sometimes the touchscreen only working, no buttons. I tried a factory reset which made no improvement.
When last driven out of the garage, the PCM came on. Buttons working at random, touchscreen okay. Rebooted itself a few times. Off again when reversing in but camera display working.
Probably too much detail but I'm trying to indicate the apparent randomness of the problem. Has anyone else had a similar experience? The same or a similar unit must be in use on multiple models.
Booked for service visit to Porsche Centre on 27th May.
