2006 Boxster S - replacement right mirror
darkfibres
Unfortunately I hit a bird on a drive out today, not so lucky for the bird in the end.
Can anyone help me to find the best place online to get a replacement right mirror for a 2006 Boxster S? It appears it is only the glass on the plastic unit that is damaged and not the unit itself, as I was able to put the mirror back in, albeit broken, but everything else seems to work fine in terms of adjusting the mirror. Is this possible to just get the glass to reattach or do I need the glass and plastic as one unit?
Many thanks!
Spencer
Talk to OPC and get a part number/prices for sure I but i suspect it's either
997 731 036 11 ( aspherical, rhd, rh side, heated and electrically operated) - approx £113 inc vat ( before discount )
or
997 731 036 10 ( flat, rhd, rh side, heated and electrically operated) - approx £92 inc vat ( before discount )
If the bit the glass mounts to is busted as well - its called an "adjuster unit" - 997 624 047 01 - £82 inc ( before discount )
If they are auto dimming then add about 200 quid to the price.
HTH
