pebattrick said:
I've just gone through two periods of pain with my '84. After a major body job and rebuilding the car, I h ad much trouble with the car to the extent that I replaced the whole starter relay unit, turns out at the end of the day, the battery hada cell gone down. The relay that engages the motor pinion is very sensitive to battery voltage, > 7.8 volts. In desperation I took the battery to my friendly garage and they pronounced that it had a dead cell (this despite keeping it topped up whilst the car was in pieces). New battery and everything was good - until last week when the starter jammed. Starter off and it performed well , back on the car and all is good so far. A freak jamming event? Who knows.
The starter itself is an easy job to remove, You do need to get the rear of the car up as high as possible and then remove the drivers side heat tube. The trickiest bit is getting a 10mm hex into the top bolt. I have found through practice (see above) that fingers can get around the body of the motor and guide the hex tool into the bolt head. A 6" extension gives enough clearance to get a ratchet spanner onto the end. An hour should get it off easily. Good luck, what else are you going to do on a sunny day?
Probably a wee bit late now - only just seen your post - but I've been going through the same pain with my 993. A click from the rear of the car and little else apart from the occasional time when it fired and ran. My starter is still under warranty as was the battery; I got a replacement battery (having tried a borrowed starter pack with instant success) from ECP but it made no difference.
Spoke by chance to a one-man garage set-up near me. Old school chap who said it sounded like an earth problem, something, he said, affected VW and Porsche a lot in his experience (he also runs a Boxster). I cleaned the earth point near the battery along with the strap tags and later tried it and it started. The car was due a service and MOT at which point changing the starter was an option. Thought I might have to trailer it but it started and got me there...
Having carried some simple checks of the system, it seems the car never once clicked while with the mechanic and he reckoned he must have started it a dozen times or so during the day and taking it for the MOT.
So, still not quite sure what the cause was or whether the cleaning of the earth connections cured it but, touch wood, all is well. A good earth is vital on all vehicles so worth keeping a check on it as it's easy to overlook the simple things.
Oh, and I've still a year to run on the starter warranty and as yet ECP haven't collected the 'old but probably sound battery'...
