Heating packed up
Guy_Nicholls7
Guy_Nicholls7 PCGB Member
2020/10/17 09:59:01 (permalink)
Heating packed up
I have a 981 Cayman on 29K +mls.
My heating has packed up.
My garage says thermostats on the model are inclined to "seize up".
Anyone familiar with this problem who has suggested remedy?
Many thanks
Guy Nicholls
Peter_Bull
PCGB Honorary Member
Peter_Bull PCGB Honorary Member
Re: Heating packed up 2020/10/17 10:03:08 (permalink)
Post moved to relevant register model area.
Forum Administrator
Honorary Member since 1998
2021 model 992 Carrera S
2019 BMW 4Series Convertible M Sport Plus, Black metallic with black leather
Located in Lancashire
Motorhead
Motorhead PCGB Member
Re: Heating packed up 2020/10/17 11:06:56 (permalink)
Guy,
It does sound like a temperature sensor-related problem. If you have climate control it could be that the cabin temperature sensor has failed.
The simplest and most cost-effective way to locate the source of your problem is to get a diagnostic check which will require a PIWIS analyser or equivalent.
987.2 Cayman S
North Beds (R10 & R24)
GrahamW
GrahamW PCGB Member
Re: Heating packed up 2020/10/17 11:21:14 (permalink)
Is it the heater or the fan that circulates the hot air?  Sticky fans are not unknown on the 981.  Suggest you check this out first.
Boxster 718s
DWaldie
DWaldie Guest of the Club
Re: Heating packed up 2020/10/17 11:30:30 (permalink)
GrahamW
......And it's a really easy fix. Is the fan running?
Motorhead
Re: Heating packed up 2020/10/17 14:10:02 (permalink)
Good call to check that the fan is working before looking elsewhere Guy. It’s quite common on the 9X1 series cars for the fan to seize, especially if the car’s been standing outside for a while. If you remove the under-bonnet cabin air filter you should be able to reach in to see if you can free it up.
987.2 Cayman S
Twinfan
Twinfan PCGB Member
Re: Heating packed up 2020/10/17 15:33:51 (permalink)
Yep, happened to my old GTS once.  Dead easy to fix.
