mail@bluebirdcarriers.com
My 1996 993 105,000 miles is in the work-shop for a crank-case overhaul. This is a biggie, engine out job & approx 50 or so man-hours I'm told.
The problem is that the crankcase is made up of 2 halves, which are joined together with 8 or 16 bolts, I cant remember. Oil flows around the crankcase and into the bolt cavities by design. At either end of the bolt, rubber O rings act as the sealant to keep the oil inside the crank-case.
All 993's are approx 25 years old now, and irrespective of the mileage, the rubber O rings are perishing as a function of time elapsed, thus causing multiple oil leaks.
My question is : what additional work should be undertaken at the same time as replacing these O rings, as hopefully this is a once in a generation event ?
Are there any upgrades one should be looking to do at this opportunity, or is keeping things original best ?
I would be very intersted in other's experience who have had this job done, and the expectation of the costs involved.
All input gladly received
