I've got a facelift Macan with the latest "wide screen" satnav. As I understand it, this should automatically download map updates via the in built data connection (it appears that my subscriptions are still live until 2 years old in 2021). However, I used the Porsche Connect app to navigate a route to Cambridge - on the phone, the mapping knew about, and routed via the new A14 (which has apparently been open for more than 6 months). When this trip synchronised to the car, the map in the PCM didn't know about the new A14 and took me via the old A14 (and a consequent diversion!). So basically the map in the car isn't as up to date as the map on Porsche Connect. Is there any way to view available updates in the car satnav and force downloads if available? Alternatively, could someone with the same version of PCM be kind enough to see whether their car mapping shows the new A14 (A1 to Cambridge) as being available. If it is, then this would confirm that my map is outdated. OPC are suggesting I may need a PCM software download / upgrade as a chargeable item as a solution, but I'm not fully convinced about this.
Thanks in advance.
Thanks in advance.
