Hi all,
First Porsche and first post on this forum, I am now the owner of a low mileage 997.1 c2s. She is in great condition but a few things are now going on a list for rectification/upgrade. I am lucky enough to have my own man cave / workshop with a ramp so working on the 11 is a breeze. I have dropped all the under panels and found the cooling system which as you would guess needs attention.
One item does concern me is the picture below, this is the front part (left side) of the aluminium pipe which goes into the engine bay. Not sure what to make of it as I would almost say it’s leaking through the aluminium!! Ordinarily okay I’ll just change it but even with a ramp it’s going to be a nightmare. Anybody have any thoughts whether its from the joint and I could getaway with just the rubber pipe. At the front and was planning to change all of them, as maybe 50% look similar to the picture below.
If any members are located in the Essex I’m more than happy for you to drop in to say hello and put your machine on the ramp for a prod ??.
Cheers,
David
Cheers,
David
