radial
To all 996 owners with PSE, especially those with a 4S.
I think my 996 C4S exhaust behaves oddly. I think it's a fault but you might tell me it's normal behaviour. The problem is that I've always had this 'fault' on my car so I don't know if it's a fault or intentional behaviour. If you have the same car, perhaps you can shed some light on this.
When I start it, it's noisy and sounds great. It quiets down as it runs for the first 5 mins.
I have the PSE system and when I press the button you can audibly hear the exhaust note change - quieter when on and louder when off. Default is off so loud.
Here's the rub. Up to around 1500rpm it's got a good noise then it fades out to the point where it's so quiet it's like driving my partners Yaris. If I keep accelerating, when I get to around 3500rpm the exhaust suddenly gets loud again. I mean it's immediate - like someones flipping a switched marked loud. It sounds great.
It happens in 2nd and 3rd gears most noticeably and the PSE is in the 'off' position. If I have the PSE button on, then it's just quiet all the time and that works fine.
So why the silent spot?
I did read somewhere that German market cars might have had a system that turns on and off the PSE at certain speeds to prevent people driving round residential streets with a loud exhaust but information is thin and I don't think I was ever on UK cars.
I have also had a small go at checking vacuum pressure at idle on both sides of the Y piece in the engine bay but both hold good pressure. One side has only a microscopic leak but not enough to cause this kind of issue.
