AnsweredHot!Ceramic Coating? Yes or No
suthe777
suthe777 PCGB Member
2020/06/07 17:58:16 (permalink)
Decided to beat the COVID blues (and BREXIT remember that!) with a new Macan, delivery is due in August/September and Porsche Edinburgh are pushing the idea of ceramic coating with G-Techniq. I have no past experience and on looking around can see there are a number of different products/technicians available locally, wondering if there are any views out there as to if its worthwhile and assuming it is, any recommendations on who/what to use.
PS New car means my 18,000 miles 2013, 981 Boxster will be available shortly if anyone is interested.  (Full details to follow)
Macan on Order.
Previously, 981 2.7, 987 II 2.9, Audi R8, 987 2.7, 986 S, 986 2.5 and 964
See best answer
Paul_Sue_Leggett
Paul_Sue_Leggett PCGB Member
Re: Ceramic Coating? Yes or No 2020/06/08 09:44:50 (permalink)
There is a very usable self-applied product available, Gyeon Q2 Cancoat that costs around £33.00.  I used this on Sue's Mini last August and it still sheds water and brings it up in a great shine.  There are plenty of similar alternatives on the market.
Regardless of whether it is applied to new paint or old the key is that the paint surface must be free of any polish, wax or contaminants.  I had a long chat with an OPC valeter who applies the ceramic coat and he said to wash the car, preferably in a shampoo without wax, dry with a brand new microfibre towel and then use a panel wipe before applying the ceramic coat (about £15 for a 500ml spray).  The instructions in the Q2 pack says to first use a panel wipe).  Applying Q2 is only a case of spraying on to the microfibre cloth provided, wiping on to the panel (one at a time) and then polishing off with another microfibre cloth.
If applying to an older paint surface then it's a case of washing, clay clean (clay cloths are so quick to use), machine polish using a mild cutting compound (ceramic coat can show up paint imperfections), wash again and then use the panel wipe.
Lancerlot
Lancerlot PCGB Member
Re: Ceramic Coating? Yes or No 2020/06/08 09:47:33 (permalink)
Gtechniq is highly regarded within the industry and their processes are beneficial in enhancing and maintaining the appearance of your car. Take a look at the company's website to learn about the various processes available before you decide which is the most suitable for you.
Once settled, I would suggest contacting the Company's official agent(s) in your area (unlikely to be more 1 or 2) and obtain quotations. Prices are pretty much fixed, I believe, but you may be able to negotiate a free DIY maintenance pack or something if you try and, in any event, it likely will be cheaper than going through your PC which may add a margin into exactly the same process.
If you decide to go this route, ask your PC NOT to carry out the usual a pre-delivery clean because this sometimes inflicts minor paint surface damage needing to be rectified by your detailer before the coating can be applied - this all adds to the cost.
Also, consider aftermarket PPF to the bumper and front section of the bonnet as these are extremely prone to paint chips immediately you start to drive it.
Past - 924T, '911 SC, 911 C, 911 C2, 964, 996, 996TT, 997TT, 997GT2, 430 Scuderia, 997TT, 997TTS, 991.2TTS. Macan SD. Raleigh bike!
delboystoy
delboystoy PCGB Member
Re: Ceramic Coating? Yes or No 2020/06/23 13:23:08 (permalink)
Snap, just booked mine in for the 1st July, full 2 Stage Paint Correction and 2 coats of ceramic for the entire car including wheel's, wheel arches and full glass treatment. Will take 3 days and got a pretty good deal at the moment with 10% off.
I would not consider the PPF myself, working part time for a Porsche specialist I see so many where a stone chip creates a tear in the PPF which actually looks worse than a chip !! as well as a line half way down the bonnet where dirt has got under the PPF and then makes it clearly visible.
I will get before and after pics if anyone interested I can ping them over.
Lancerlot
Re: Ceramic Coating? Yes or No 2020/08/24 20:35:37 (permalink)
Just been putting in a little more research on this topic. The perceived wisdom seems to be as follows:-
a.) Ask the dealer NOT to clean the vehicle during PDI and prior to handover.
b.) Level 2 detailing (thorough washing, decontamination, polishing & paint correction).
c.) Apply PPF to desired areas.
d.) Apply Gtechniq Halo to all PPF and Serum Light / EXO combo to all paintwork.
3.) Apply Gtechniq C5 Wheel Armour to alloys, callipers and exhaust tips.
Total cost seems to be in region of £3-£3.5K depending on the detailer and PPF coverage.
AndrewCS
  • Status: online
AndrewCS PCGB Member
Re: Ceramic Coating? Yes or No 2020/08/24 22:10:05 (permalink)
See Brian Innes`s Macan Turbo thread for further details …
Having had three, used white Cayman`s treated with the OPC`s gtechniq Platinum ceramic coat package I can thoroughly recommend it (~ £550)
Most of the `chips` on the Caymans` are on the windscreen and leading edge of the roof together with the usual `road rash` on the lower bumper behind the rear wheels (plus the GT4`s engine air intake `cowls`)
It was at OPC Edinburgh that I saw a PPF`d Cayman GTS in red, the lack of adhesion - whitening below the `film` put me off the process / product
Aberdeenshire (R2) : Cayman GT4 981
stephentodd
stephentodd PCGB Member
Re: Ceramic Coating? Yes or No 2020/08/27 12:27:53 (permalink)
I have a G3 Glasscoat ceramic coating on my Macan S which was re applied by the OPC and it is fantastic but no idea of cost as it was a s/h purchase,  i also
have a 986 Boxster with a ceramic coating on, as does my wife's Toyota, it certainly makes washing the cars very easy, the muck just seems to lift off, they also seem to stay cleaner longer.
Brian_Innes
Brian_Innes PCGB Member
Re: Ceramic Coating? Yes or No 2020/08/27 15:06:16 (permalink)
suthe777,
I can unequivocally recommend your new Macan currently on order being given a proprietary ceramic paint treatment on the bodywork, wheels, glass, and carpets. The long-lasting benefits are significant, the easiness of washing off insect splatter and road grime the most obvious.
As well as providing a long-lasting shine, up to at least 2 years in my experience, the paintwork is so silky smooth to the touch it makes washing the car and drying it off a far more enjoyable experience.
The Jury is still out regarding the application of PPF film on my Macan. Previously, I had Expel PPF applied to both my previous 718 Caymans. There are adhesion issues that may arise, and stone chips can still be evident having penetrated the film in some instances. It's all a matter of velocity and size of the stone in question.
Brian
Nairnshire,
Highlands
Previous:
2007 Cayman 987.1 2.7 Manual.
2010 Cayman S 987.2 Manual
2012 Cayman R Manual
2015 Abarth 595 Competizione 180
2016 718 Cayman S PDK
2019 718 Cayman GTS PDK
Current:
Gen 2 Macan Turbo
Gander101
Gander101 PCGB Member
Re: Ceramic Coating? Yes or No 2020/08/31 18:17:57 (permalink)
Our new Macan GTS Paid a visit to Topaz Bristol pre delivery to have a ceramic coating applied, very impressed, by far the best prepared new vehicle we have taken delivery of, so impressed was I that the GT3 got sent for similar treatment.
Attached Image(s)
Paul G (R16)
Gander101
Re: Ceramic Coating? Yes or No 2020/08/31 18:19:04 (permalink)
The other car .....
Attached Image(s)
Paul G (R16)
Lancerlot
Re: Ceramic Coating? Yes or No 2020/08/31 18:38:14 (permalink) ☼ Best Answerby suthe777 2020/09/25 23:40:19
Pricey though wasn't it?
Level 2 detail at £800 and serum light + exo at £500, then VAT on top!
Were you able to get any sort of deal on that?
suthe777
Re: Ceramic Coating? Yes or No 2020/09/25 23:55:09 (permalink)
After all the input I went for it and PC Edinburgh applied the treatment before collection, I managed to "get a deal" on the cost.  Spent a few days up north last week (saw Mr Innes in his Blue Turbo very briefly, as we passed each other in opposite directions) and the car returned south with numerous dead insects spoiling the paintwork!!
The car was very easy to wash and came up looking great, so first impressions are certainly positive.  Like Brian I am still getting used to the bigger car after my run of 5 Boxster's but I am enjoying it and find it very comfortable and you certainly get a good view of the road ahead with the higher seating position.
David
Macan on Order.
Peter_Bull
PCGB Honorary Member
Peter_Bull PCGB Honorary Member
Re: Ceramic Coating? Yes or No 2020/09/26 09:48:14 (permalink)
suthe777
After all the input I went for it and PC Edinburgh applied the treatment beforecollection.................
Did the PC Centre do this themselves or did they get in a detailing company to carry out the work?
Forum Administrator
Honorary Member since 1998
2021 992 Carrera on order for October build
2019 BMW 4Series Convertible M Sport Plus, Black metallic with black leather
Located in Lancashire
CLIFFWILKINS
CLIFFWILKINS PCGB Member
Re: Ceramic Coating? Yes or No 2020/09/26 13:19:14 (permalink)
Just because it's got ceramic coating don't forget a correct wash method .
It can still be damaged and expensive to repair .
I wonder in a few years time now much to remove repair and recoat again.
There is advantages and disadvantages in my view just depends on what you want and how much one wants to spend.
Enjoy
Assistant Register Secretary
Following: @BoxsterRegister
Current cars
Cayman R Peridot
Boxster 981 GTS White
Previous
GT3 Mk 2
GT3 Mk 1 S/Y Missed
Cayman Sport Viper Green
996 4S
4 986 Boxsters
987 Boxster
3.2 Carrerra
944 &924
suthe777
Re: Ceramic Coating? Yes or No 2020/09/27 16:18:13 (permalink)
My understanding is that the Porsche Centre did it themselves, they have an appropriately qualified detailer.
Macan on Order.
