Hot!Alarm issues
devans
devans Guest of the Club
2020/05/16 20:15:30 (permalink)
Alarm issues
Hi, not been on here for a while as I laid my Porsche up for two years. However, looking to get it back on the road now as I’m missing it. However, whether the car is alarmed or not.... the alarm keeps sounding. When I use the alarm unit it clearly clicks and the lights blink twice when locking and once when unlocking which would indicate to me that the unit is talking to the car. I could understand the alarm going off if a window is left open or a catch isn’t quite making a connection, however, I cannot understand why it’s going off when not set. Central locking seems fine. Only things I have done are 1. Fully charged the battery and 2. Disconnected the rear and front bonnet operating levers by the drivers door which I needed to do to get the bonnets open when the battery was flat. Any help would be appreciated. Thanks
Porsche 996 C2 Carrera Zenith Blue with GT3 Aerokit
Porsche 944 lux Bronze 1986 (Kept for 14 years) before moving to a Carrera
kasspa
kasspa PCGB Member
Re: Alarm issues 2020/05/17 22:23:26 (permalink)
Charging the battery is one thing, it holding the charge is another..... have you had any issues with windows lowering or the rear spoiler coming up?
Strangely, this does happen when battery is faulty & obviously depletes it further + it triggers the alarm siren....
2004 996 C4S Manual Basalt Black with Black Leather
majordom
majordom Guest of the Club
Re: Alarm issues 2020/05/18 09:01:12 (permalink)
i suggest a new battery
devans
Re: Alarm issues 2020/05/18 12:19:02 (permalink)
Hi, thanks for your response, however battery is fine and no issues with windows. Spoiler is a fixed GT3 dual blade.
Terry
Terry PCGB Member
Re: Alarm issues 2020/05/18 13:08:10 (permalink)
The battery remains the most likely culprit. What happens when your battery charger is attached to the car? If that cures the problem it would confirm the battery is the issue. If not it will be an alarm unit fault.
Terry Perry
991.2 GTS Coupe
981 Boxster S
Richard_Hamilton
Richard_Hamilton PCGB Member
Re: Alarm issues 2020/05/18 13:55:18 (permalink)
I would suggest temporarily disconnecting the tilt sensor and siren.  It might be that the siren backup battery is low/failing, or the tilt sensor has water ingress.  Switch on the ignition before disconnecting.  You will probably get a single beep on locking, but at least it might eliminate these devices from the possibilities.
Richard
2017 Cayman S & Audi RSQ3
Previous:
75pno
75pno PCGB Member
Re: Alarm issues 2020/05/19 20:38:18 (permalink)
I had this a year or so ago, alarm would go off for no reason , locked or unlocked , as Richard has said the tilt sensor gets moisture in it , so I took mine out and removed the alarm siren too. Everything still works fine , locking / unlocking etc. I did contact my local OPC , evidentiary there is a upgrade tilt sensor available that is repositioned under the passenger seat and I think the kit cost was around the £350 mark. The original one is next to the main car battery , which I’m sure you know already !
75PNO
devans
Re: Alarm issues 2020/05/21 19:07:50 (permalink)
Thanks Richard and 75 pno. As I stated earlier it's definitely not the battery as it holds 12.9 volts and was fairly new when I laid the car up. I know things can play up once the battery drops below 10volts but this issue is a new one. If I put the key in position, disconnect battery then reconnect and start the car, everything is fine. However, as soon as I switch the car off and remove the key I get a beep and the alarm sounds. At this point nothing can switch it off. If I try to put the key back in the ignition, if I set the alarm with the key fob and then set the alarm off.....nothing works with regards to cancelling the siren. Only goes off when disconnecting the negative terminal. The whole issue therefore starts when I remove the key from the vehicles ignition switch.
i will look at removing the tilt switch and siren and give a clean but with this latest information do you think it can be anything else. As I say, it is triggered when I take the key out of the ignition switch, thanks
devans
Re: Alarm issues 2020/05/21 19:11:52 (permalink)
Hi Richard, I've just posted an update on the alarm issue to see if you feel it can be anything else. However, you mentioned  siren back up battery. Is this on the siren itself? If not, can you point me in the right direction please. I will have a look tomorrow, thanks
devans
Re: Alarm issues 2020/05/21 19:41:48 (permalink)
Forget that Richard, just took off the backup battery box. It does have 4 screws but is pretty much a sealed unit so I'm assuming the whole thing would need replacing. The tilt switch box also looks to be a sealed unit. Apart from cleaning contacts there's not a lot that can be done with either I suppose
Richard_Hamilton
Re: Alarm issues 2020/05/21 19:49:28 (permalink)
The backup battery is inside the siren itself.  I think that the backup battery voltage may be too low, and when you remove the key from the ignition it "thinks" it is being disconnected and sounding.  Cleaning it probably won't do any good, but if you disconnect it (with the ignition on) it might at least eliminaate it as being the culprit.
Richard
Previous:
devans
Re: Alarm issues 2020/05/21 20:41:16 (permalink)
Guys, had both the siren battery backup out and the tilt switch. As I said earlier, both units look pretty much sealed. Contacts to the tilt switch were shocking. Green and difficult to clean. However, contacts cleaned as best as I could and 'hey presto' success. Hope it lasts this time. ive always wondered if my unit was. Sat correctly in the car ever since I bought it years ago as the bracket that holds it all has always looked bent. The rubber shock absorber at the bottom was always in the middle of nowhere so while I was fitting it back I bent th bracket so the shock absorber was touching the bulkhead where I think it should be. Let's hope it all remains working before the neighbours start complaining. Many thanks for all your help again. Stay safe
kasspa
kasspa PCGB Member
Re: Alarm issues 2020/05/21 21:42:06 (permalink)
Excellent news re your fix & at no cost apart from your time..... a good point of reference for all us 996 er's should we ever experience similar.......
Thanks for posting your +ve result
devans
Re: Alarm issues 2020/05/22 15:20:40 (permalink)
Cheers Kasspa, I attempt almost anything when trying to fix faults. However, would not be able to solve much if it wasn't for the advice I receive on this forum. It is always my first point of call and over the years have been very appreciative of everyone's comments, in particular Richard. Just got to refurbish wheels now and look at getting it on the road for the summer. All serviced and just about ready to go
kasspa
kasspa PCGB Member
Re: Alarm issues 2020/05/23 21:52:21 (permalink)
Yes, what would we do without Richard's amazing knowledge.....
I must admit my 4S has been idle despite never SORNED & am eager to give her a 'blast'.....
