Only 13volts
- Thread starter Mark996
At 12.4 volts, a car battery is 75% charged while at 12.2 volts it's 50% charged.
You don't provide much information for a diagnosis.
But work through all the usual electrical tests and this should reveal the fault. Check for any loose or damaged connections (ensure the engine earth is sound), check the heavy duty cabling from battery to alternator and starter and confirm the alternator is actually charging the battery. Check the starter motor.
If the battery is new, it should be OK, but if all else fails have this tested for heavy discharge as it could be faulty.
Horsesoldiers
Thank you all for your help.
My car is now fixed.
As suggested the starter was lazy dragging a lot of power along with the main cable crimps being iffy.
New starter and my ends re crimped with the addition of an extra cable to assist the oe main cable and all looks good.
Now if you could fix Covid19 I can enjoy the car.
Thanks again and stay safe everyone, see you on the roads asap.
Mark
garyw
Moderator
Lancerlot said:My lawn mower has just started to display similar symptoms,
Is that an issue the fella pulling the rope or other LOL []
unclewinks
mine has just started hunting
dirty throttle body maybe ??
unclewinks
thank you for the advice
hope you and Judith are keeping well and safe ??
paul
