Just had the high pressure pipe into the steering rack spring a leak with a pin hole, hydraulic fluid everywhere underneath. Just wondered if this has happened to anyone else?
Apparently getting the pipe out of the rack as well as the low pressure pipe out successfully is very tricky as it's steel against alloy and they corrode together so it might mean a new steering rack as well! It's mounting up and this is after I had both metal steering rack pipes and both return hydraulic pipe ferrules replaced last year as a precaution.
I suppose owning a 15 year old car albeit with only 55000 on the clock things are bound to deteriorate.
Jon
Jon
