My 993 has developed a couple of slight oil leaks which is no surprise!
I removed the undertray and there was a quantity of oil accumulated in it and enough for some to have found its way to the garage floor which is how I spotted it. Looking up it appears to be coming from the valve covers and cam chain covers on the near side. There was also some oil on top of the heat exchanger so I assume this had dripped from the valve cover. Some of the lower fixing bolts are definitely wet.
I tightened the cover bolts slightly but not sure yet if that has made any difference - i doubt it.
My question is therefore: is it possible to renew the gaskets on both the lower valve covers and chain covers without removing the engine? I would propose to do both sides. The upper valve cover appear dry.
Many thanks
Many thanks
