RoboBongoCuckooCop
Howdy, I've one of those issue's that's proving to be a bit hard to diagnose as it doesn't do it so much when the cars stationary, and the car needs be fairly warmed through to start doing it (though once it starts, it doesn't really let up). I've taken it to the garage a few times but so far not managed to get it to do it while stationary in front of them. They've said it's maybe something that needs to get worse before it gets better, but it's been doing it for a few months now and it's really starting to grind.
There's a bit of a ticky/tappy rattle that is synchronous with engine rpm. You can get a bit of a burst of above 2k rpm, but it really tends to do it when you lift off the throttle, typically going down a hill below 2k rpm, all the way down to 1100rpm where it'll stop. To give you a sense of speed, at 1300rpm it's like maybe one tick a second, increasing in speed with revs.
With the roof down, it can be fairly loud. With the roof up, it's quieter but more distinct and isolated. With the roof up, it sounds like it comes in off the back of a little off beat whiring and harshness. It sounds like it's just behind the centre glove box fairly central with the roof up.
The one time I have managed to get it doing it while the car was stationary, I took a video. It doesn't give you a sense of the speed of the tick with rpm, but at least you can hear it doing it:
https://youtu.be/P31BF9VkFv0
